xenon bulbs
Started by raywilb, 15 June 2016, 17:23:29
raywilb
I'm sure their is a post about types of bulbs needed to replace blown ones, but I don't seem to be able to find it. its the xenon headlight ones I'm interested in mainly. I had a brakelight bulb go, which has prompted me to carry spares.
HID bulbs are D2S 4500K is the norm on here
You cant 'realistically' change em at the roadside, according the manual they are dealer repair only.
Frankly, I wouldnt carry a spare unless you had one knocking around, a phillips or osram replacement will be about £50!
raywilb
Quote from: Jimbob on 15 June 2016, 17:49:52
No, I had an idea the headlights weren't a roadside job, but was thinking in the lines of keeping a spare set & probably carry rear end ones in the boot.  :y
Easy enough job to swap out - just need to wait and wait before starting, otherwise a quick job - changed a couple myself without problem  ;)
And these bulbs are hardly robust things to keep just in case one fails. Especially at that price. It was hard enough keeping ordinary H3/4/7 bulbs as stock for roadside jobs; even keeping them in a foam block I often found that they hadn't survived.
Changing the xenon bulbs requires removal of the light unit to be able to reliably remove and refit the torx screws securing the rear cover. Whilst you could do this at the roadside, at home is a much safer proposition  ::)
Mr Gav
Quote from: Nick W on 15 June 2016, 18:11:15
I bought a couple around eighteen mons ago from Autobulbs direct, around £75 for the pair IIRC
Quote from: Mr Gav on 15 June 2016, 18:40:17
I bought a couple around eighteen months ago from Autobulbs direct, around £75 for the pair IIRC
I would have no problems with the price if I had to replace blown ones. But I have never understood the thinking behind buying and carrying a brand new part  just in case the existing used one fails. I can see some justification in keeping the old one as a spare.
If you do buy some, replace your existing ones, and use those as spares.
Xenon lights, like LED and to a lesser extent tungsten, do degrade with use.
Mr Gav
Quote from: TheBoy on 15 June 2016, 19:26:45
Agreed, when you replace them it`s surprising how much difference new bulbs make.
Quote from: Nick W on 15 June 2016, 18:54:57
As a bulb that rarely blows I wouldn`t carry one around either, I couldn`t see the point.
