Author Topic: Window lock?  (Read 8252 times)
TD
  • Swindon
    • Nowt!
Window lock?
« on: 19 February 2017, 16:52:25 »
I want to restrict how far one of my UPVC top opening window opens....say to 4 or 5 inches
Its the downstairs bathroom window.
I have a shower in the morning and used to leave the top opener open all day for ventilation. But since getting broken into about 18 months ago (that's how they got in....through the bl**dy top opener!) I leave it in the 'vent' position, which only leaves it open by about 1/2 inch...which isn't enough to allow the bathroom to dry out....
Ive been having a look about, but cannot see anything suitable.....
Any ideas chaps.....
Re: Window lock?
« Reply #1 on: 19 February 2017, 16:57:37 »
Extractor fan?  :)
« Last Edit: 19 February 2017, 17:11:50 by Jimbob »
TD
  • Swindon
    • Nowt!
Re: Window lock?
« Reply #3 on: 19 February 2017, 17:21:43 »
something like
http://www.diy.com/departments/yale-white-ventilation-window-lock/254586_BQ.prd
Ive seen similar to what they use in hotels too
edit : https://www.homesecureshop.co.uk/cable-window-restrictor-child-safety-lock-max6mum-security
or
https://www.homesecureshop.co.uk/safe-t-bar-upvc-door-window-chain-restrictor
Ive looked at all three of those...
1st one .... no good as it needs quite a large area of the frame to mount one side of it....which my window hasn't got
2nd  .... I was concerned the cable length was too long ... I only wanted to open the window for or 5 inches
3rd ... Looked a bit flimsy to me......
TD
  • Swindon
    • Nowt!
Re: Window lock?
« Reply #4 on: 19 February 2017, 17:32:51 »
Extractor fan?  :)
Thought of that.....flat roof....so impossible to run a cable for it... I reckon
Re: Window lock?
« Reply #5 on: 19 February 2017, 18:07:42 »
What length hinge is on the transom?
TD
  • Swindon
    • Nowt!
Re: Window lock?
« Reply #6 on: 19 February 2017, 18:19:36 »
Isnt the transom the horizontal bar between upper and lower window  :-\
If so I don't understand the question  :-\
Re: Window lock?
« Reply #7 on: 19 February 2017, 18:28:16 »
How long are the hinges?
Re: Window lock?
« Reply #8 on: 19 February 2017, 18:29:13 »
It is. So, I guess, Rob means the top of the frame.
Re: Window lock?
« Reply #9 on: 19 February 2017, 18:32:23 »
He means how long is the hinge... Presuming that the hinges are side and not top mounted ;)
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Window lock?
« Reply #10 on: 19 February 2017, 18:33:37 »
Restrictor stays.
Re: Window lock?
« Reply #11 on: 19 February 2017, 18:35:32 »
If you leave it open even an inch, someone who wants in will get in.
Re: Window lock?
« Reply #12 on: 19 February 2017, 18:36:36 »
Restrictor stays.
I could draw one, but now I know what they're called 8)
Re: Window lock?
« Reply #13 on: 19 February 2017, 18:37:38 »
Pedant :P ;D Transom is the bar, but the opening window/vent above is also known as a transom
Re: Window lock?
« Reply #14 on: 19 February 2017, 18:39:18 »
Restrictor stays.
If you mean "hinges". restrictor hinges are manufactured @ 10" or 250mm at their shortest. Hence my question.
