Anyone know about Astras?
Started by JamesV6CDX, 03 April 2020, 00:17:23
Quote from: STEMO on 27 May 2020, 22:00:26
Quote from: JamesV6CDX on 27 May 2020, 21:50:59
Every 40 miles or so, I get a fault code, DPF low effeciency.
Not sure that can be, given it's empty!!
When it does this, it over fuels, and stinks like a bad bbq
I fear I may just fit a pattern DPF  :-X
Thought you'd ordered a new dpf?
No you're misreading. I said I'd ordered a new "DPF Back" exhaust, meaning everything behind the DPF :y
Ah, I see. Thought it was already decided that it needed replacing or software remapped.
Quote from: STEMO on 27 May 2020, 22:34:27
It was. Just haven't pulled my finger out!
If I was going to keep her, I'd try be tempted to try and fudge the sensors somehow. But, I anticipate in a few months, I will sell her on in order to buy a bigger and better project... and I wouldn't sell it without a DPF, and risk the new owner running foul of MOT rules :y
Quote from: JamesV6CDX on 27 May 2020, 22:37:10
Would you not be better with a used OE DPF?  :-\
Good luck here, unless your good at automotive electronic design and sw programming  :y
Quote from: Andy B on 27 May 2020, 22:51:35
I certainly wouldn't consider a used dpf. They have a life span even when treated right, and you'd have no idea how it had been used. Quite a few drivers don't understand it's purpose or even what a regen is.
Quote from: STEMO on 28 May 2020, 12:34:54.....
I see what you mean but cost dependant it might have been an idea rather than shell out £££££s for a new pattern DPF
About £200 for a pattern DPF on an Astra, think there are two types dependent on the exhaust fixing (slotted or drilled hole).
Sadly, the original DPF was probably ok and just needed a regen
Raeturbo
Can you buy a used one and clean it before it's put on?
Laying a rubber road.
Quote from: Marks DTM Calib on 28 May 2020, 14:41:09....
Is it possible to do something with a DPF when it's off the car?  :-\ :-\
Quote from: Andy B on 28 May 2020, 16:46:18
Plenty of companies will squirt a magic solution through it for you. But why bother when £200 buys you a cheap replacement?
Quote from: STEMO on 28 May 2020, 16:57:56
Is the cheap pattern worth fitting? They say that pattern cats are crap so are pattern DPFs any better?   :-\
I really meant,  was there anything off the shelf you could buy to sort it DIY?
Quote from: Andy B on 28 May 2020, 17:11:30
Not that I know of. If you pay £200 for a cheap dpf and it lasts 3 years, I'd say that was ok.
Don't know how many miles James' astra has done, but there are plenty for sale with over 100,000.
Yes, it is possible to fully clean and de-ash a DPF, its been done for years on commercial vehicles  :y
.........and its more than just squirting a fluid through, it involves ultrasound, reverse flushing and special solvents
