Pages: 1 2 3 4 5 6 [7] 8 9 10   Go Down
Author Topic: 17 year old Corsa C won't start.  (Read 44984 times)
Re: 17 year old Corsa C won't start.
« Reply #90 on: 01 January 2021, 13:39:23 »
 ;D
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #91 on: 01 January 2021, 13:44:45 »
New Year , new car don't be such a tight arse..😃😃😃
I'd have been tempted by your old Merc.
That went back to MTSV where I bought it from, he sold it almost immediately it was exceptional though.
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #92 on: 01 January 2021, 14:05:41 »
Get your colleague to listen by the pump to see if it is making a noise while you crank to engine. But.. if you simply pull the plugs you will see if they are wet if they are it’s obviously getting fuel. Whilst it’s dismantled you can then simply check for a spark at the plugs. If you have fuel and spark then it is most probably a mechanical problem
Filipino house boy/serf.  ;)
    • Grandland 1.5 diesel
« Reply #93 on: 01 January 2021, 14:15:26 »
Poor lad doesn't want to be bending over the bonnet with Opti about.
Diesel till I die
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #94 on: 01 January 2021, 14:28:18 »
If he buys Mrs Opti a new one then he will have to buy all his mistresses one too  :o
so he should probably enquire about a fleet of these clicky
good MPG and not too hard to work on  :)
ronnyd
« Reply #95 on: 01 January 2021, 15:23:18 »
Dunno Dave, the fitting of the bag onto that frame looks a bit tricky. ???
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #96 on: 01 January 2021, 16:05:43 »
he could read the instructions
or start a new thread on OOF  ;D
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #97 on: 04 January 2021, 16:13:49 »
Get under the Car and bash the f*ck out of the plastic fuel tank, preferably with someone cranking it.
Fuel pumps are common issues on these and sometimes a good wack can be a temporary fix.
« Reply #98 on: 06 January 2021, 13:42:28 »
Tried again with a fully charged battery. SFA.....not even a glimpse of it wanting to spark into life.
I've called the RAC man with an ETA of 3-4 hours.
I'll see what he says. My guess is fuel pump. :)
« Reply #99 on: 06 January 2021, 14:13:23 »
You should have bought one and had it ready for him to fit when he arrived.
Diesel till I die
« Reply #100 on: 06 January 2021, 14:29:29 »
I think it may be fuel pump.....I wouldn't bet my house on it though. :-* :-* :-*
« Reply #101 on: 06 January 2021, 16:18:35 »
Lift the rear seat base, pop the circular cover off and listen......then idiot it with something soft
« Reply #102 on: 06 January 2021, 16:28:06 »
His head?
Diesel till I die
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #103 on: 06 January 2021, 17:55:46 »
Cruel.  ;D ;D
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #104 on: 06 January 2021, 18:05:44 »
I imagine the RAC have been out ,looked, told him to take it to a garage to be fixed
i doubt RAC would fit a fuel pump IF that is the issue
Pages: 1 2 3 4 5 6 [7] 8 9 10   Go Up
