Pages: [1] 2 3 4 5 6 7 8 ... 10   Go Down
Author Topic: 17 year old Corsa C won't start.  (Read 44947 times)
« on: 27 December 2020, 15:19:45 »
Plenty of petrol and cranks fast on the battery.
No codes either stored or pending on Maxiscan MS509. No warning lights or 'flashing spanners'
    • Grandland 1.5 diesel
Re: 17 year old Corsa C won't start.
« Reply #1 on: 27 December 2020, 16:21:38 »
It's probably died of boredom.
Diesel till I die
« Reply #2 on: 27 December 2020, 16:24:03 »
Oh dear.... They say these things come in threes.  ::)  First the mower doesn't want to play and now Mrs Opti's Corsa.  :-\
Maybe we should start a poll.  What's next to shit its self?  The Jaaag or the Signum.  :-\
« Reply #3 on: 27 December 2020, 16:26:45 »
Or the man himself. He's talking about parting with a few hundred quid for a widow maker.
Diesel till I die
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #4 on: 27 December 2020, 16:28:27 »
how long has it been stood ?
has it got oil in ? and antifreeze  not water only in the cooling system ?
1 L 1.2 or 1.4 ?
can you hear the fuel pump when you turn to accessories ignition position ? (dash lights on)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #5 on: 27 December 2020, 16:30:33 »
Have you dropped the key and lost the immobiliser chip?
« Reply #6 on: 27 December 2020, 16:38:44 »
It's the mighty 1.2 SXI of 2003 vintage.
It was lasted started a couple of weeks ago and all was fine. No hint of it 'catching'.......it turns over fast without a hint of life.
« Reply #7 on: 27 December 2020, 16:42:48 »
No....and I've just tried the'basic' spare key ( the one that can't operate the central locking system)
  • Chatham, Kent
« Reply #8 on: 27 December 2020, 16:49:41 »
Was it started and turned off without being driven?
Crank it over with the throttle wide open for 30 seconds.
« Reply #9 on: 27 December 2020, 16:59:27 »
Yes.....never really driven as it is SORN. I'll give it a go.  ;D
« Reply #10 on: 27 December 2020, 17:03:26 »
Nope. No success.  Il est mort.  :'(
Battery still good though. :y
« Reply #11 on: 27 December 2020, 17:10:01 »
All the fuses good?
  • Chatham, Kent
« Reply #12 on: 27 December 2020, 17:11:25 »
Then you need to do some work:
Remove the plugs, and dry them with a flame. Inspect them for wear and damage; replace if necessary
Pull the fuel pump fuse, and crank it over with the throttle open again. Do that a few times.
Ensure the battery is fully charged.
Refit the plugs
If it was flooded, it should now start.
Cars are feminine, so elle est mort 8)
« Reply #13 on: 27 December 2020, 17:18:37 »
Refit the plugs
Thanks Nick.....coil pack is a piece of piss to lift on the Corsa. Car has only covered 29000. Plugs were changed at around 22000  miles. Hardly ever used.
« Reply #14 on: 27 December 2020, 17:22:03 »
Actually I meant to say 'it is dead'.....my command of the french language leaves much to be desired. :-X
Pages: [1] 2 3 4 5 6 7 8 ... 10   Go Up
