Quote from: TheBoy on 19 June 2015, 21:24:10
Scrapped it quite heavily getting on and off the ferry  :'(
That will teach you for Chavin it up, with silly bumpers  :D
Quote from: tunnie on 19 June 2015, 21:29:24
It was its midrift. Suspect too much shite in it. Bleedin' wimin!
Andy A
Sanding the front bumper down on the Omega ready for some filler and paint.  :y Only wish I had an irmscher front bumper in Z157.
Quote from: tunnie on 19 June 2015, 20:49:02
Quote from: chrisgixer on 19 June 2015, 17:39:30
Quote from: tunnie on 16 June 2015, 15:55:01
24? From a 4.5 V8. Not bad  :)
Yeh, the 3.2's really are shite on fuel!  :(
Bit like people moaning that sky is too expensive that. OF COURSE ITS SHITE on fuel. It's a 3.2 v6 auto in a car weighing nearly 2 ton.
....AND the lazy wingebag owner hasn't bothered his arse to convert it to LPG yet. ;D
Then how come V8s with loads more power, more cubic capacity and couple of extra cylinders. Along with extra weight, do better on fuel.
No, the 3.2s are shit engines, similar power output of the 3.0 yet the 3.0s are far, far better on fuel. Difference to power/mpg is not equal between them.
Two words...
Torque and power-to-weight-ratio ;)
Besides, 3.2 can't be that shit... I have two with a combined mileage of 450k miles, on the original running gear...
Shackeng
Quote from: Harris K Telemacher on 19 June 2015, 22:05:16
Two words...
3.0i V6 24V Elite 4d Auto 0-60 9.0 secs Top Speed 148 mph
3.2  V6 24V Elite 4d Auto 0-60 8.0 secs Top Speed 149 mph
steve6367
Had a new windscreen fitted - not convinced though - trim is already falling off  :-\
Quote from: Shackeng on 19 June 2015, 22:37:55
Two words...
I was thinking of the LS1/2/3 compared to the V6... Alot more torque from alot lower down... Of course fit a 3.45 diff to an Omega and I reckon you wouldn't be far off 40mpg ::) it would be a slug off the line though compared to the standard ratio :D
You could also point out that the manual 3.2 is a sub 7 second car... But then some smart arse would argue that it wasn't a retail model and therefore doesn't count ;D
Quote from: steve6367 on 19 June 2015, 22:47:52
Get them back to fit it properly then ;)
MikeDundee
Quote from: Harris K Telemacher on 20 June 2015, 00:14:09
Two words...
I would like to point out that the manual 3.2 is a sub second car, and is not a retail model so doesn't count :y ;D
steve6367
Quote from: Harris K Telemacher on 20 June 2015, 00:14:54
That's today's job the ring them, I think the actual screen is ok. Frustrating as I ask them to bring new trim when booked, they said yes they would then didn't!
Quote from: steve6367 on 20 June 2015, 06:57:26
Usually means that the screen has been fitted too high in the aperture... that said, the trims can be quite variable depending on the supplier and some are less reusable than others ime :-\
steve6367
Quote from: Harris K Telemacher on 20 June 2015, 07:32:47
It's certainly not at a uniform depth in the apature - more recessed drivers side vertical and less so passenger side.
GM's figures on 3.0 are particularly conservative.
The 3.0 is quicker and more economical than the 3.2
The Sheriff
Quote from: TheBoy on 20 June 2015, 08:31:19
Esp. If it's black  :y
chrisgixer
So how come mine, keeps up with yours which is chipped. No problem at all? As does Kevin's actually iirc
