chrisgixer
Quote from: pauls on 27 June 2015, 19:44:43
Had new battery fitted this morning(Thanks Birthday Boy ;D ;D).
This afternoon I thought I would whip the rear bumper off and change the bumper bar, it turned out to be a 6 hour job >:( bar was twisted and split and bent, managed to get it off just to find brackets twisted and bent and the back off the car had been pushed in.
Anyway after 6 hours new bar on nice and straight irmscher bumper sitting nice and hopfully no more rattles.
Somebody been playing bumper cars previously. :(
But how's the gremlins, so far?
That car has definitely had a whack up the arse at some point... No chassis damage as I recall though :y
pauls
Drove fine on the way home...Time will tell
pauls
Quote from: Harris K Telemacher on 27 June 2015, 21:11:46
No  no chassis damage it just punch the bracket plates back about  2 inches on the passenger side.
I recall seeing summat when investigating that rattle...  Was the bottom of the bumper attached? Memory is a bit hazy, not helped by having repaired another silver Elite at around the same time... ::)
pauls
Quote from: Harris K Telemacher on 27 June 2015, 21:34:48
yes it was I put nuts and bolts thru them. I think after taking it all apart then putting new bar on and bumper the bumper does not move around as much. Time will tell but I think it was all down to the bar been swashed against the body.
Re-wired the hardwire for the dashcam to a different power source - one that wouldn't cause interference on the CID.  ::)
Delroy47
Change a bulb in the high level brake light and now its raining  >:(
joff
Took the elite to have an Air-Con re-gas only to find out I need a new HP valve, which will be here in the morning :(
Shackeng
Quote from: joff on 30 June 2015, 16:07:04
Spooky, I just got off the phone to my local guy who will take what little gas is left out of the 3.2 on Thursday, I'll fit 2 new valves, and then he'll regas . Charged me £30 last time. :y
The Chav turned over 100k  :'(, at speed  :D
Found that one of the pressure sensors on the Alhambra's AC is faulty - which according to a certain code reader is intermittent - funny really as when you clear the code it comes straight back so I wouldn't say it's that intermittent.  ::)
Reset the 0420 / 0430 codes on the 2.6... I really must fit some Lamda's in the bosses fitted by Daz 18 months ago  ::) ;D
Booked big blue in for geometry at Nigel langs in the morning.
Air con nitrogen pressure tested... passed no leaks, vacuumed down
refilled with oil and refrigerant, temp from the vents 7 degrees C with an air temp of 22 degrees C... I is happy with that !!  :)
SO, many thanks to Mark DTM for the replacement compressor, Daz for fitting it, and Taxi Dave for the contact details of the air con man ...
Thanks to OOF we'll be nice and cool in France .. :)
Quote from: Entwood on 30 June 2015, 20:02:05
It was rather warm when I was there a few days ago ;D
I suppose at some point I should get TBE regassed, as no history of it having been done in the last 12 years...
