Quote from: minifreek on 09 July 2015, 22:52:02
You gonna let us guess as to why....?
OK my best guess is - the DAB antenna was either unplugged or broken/knackered....
That is what I  assumed :-\ but it turned out to be caused by the wireless charger I bought recently for my mobile phone :(
Unfortunately  I had my hand up behind the  radio to check for loose connectors and tbe FM aerial plug fell out so I am  going to have to pull the radio to get that working again  :(
Quote from: minifreek on 09 July 2015, 20:20:34
Just had 3 tyres fitted on me motor as the fronts was a bit errrrm worn (hadn't noticed the tread was down to the very very limits until the other day when I changed the front pads), 1 rear was also slightly above the wear blocks so had 3 Dunlop Sports fitted :)
All legal for the drive down to Billing now :)
And presumably absolutely nothing to do with your geometry... ::)
jimbo125
Could be the camber and not using B4s ;D
2.5V6 Had it since 2002, what a beast, worth the time and effort to keep it road worthy. Vauxhall bring them back!!! Laser timing kit for OOF member hire
4x4
Maybe he just needed new tyres as they needed replacing due to low tread and opps all to do with geometery.
EMD
Omegatitis
BazaJT
Inflated both rear tyres as they'd gone flat-think they're leaking round the rims-due to car not moving since March.
biggriffin
Quote from: EMD on 11 July 2015, 07:50:36
Eaten a bacon sarnie in it  ;D
Went to billing and despatched a pigeon on the way. That'll teach it for getting in the way. :D
Hoof'land storeman.
Darth Loo-knee
A new alternator fitted this morning so now lovely and quite lol... put a cruise control stalk on just need to be tech2'd now  :y
mka306
Quote from: Darth Loo-knee on 11 July 2015, 17:38:03
Do you have tech 2 Daz?
Quote from: mka306 on 11 July 2015, 17:54:31
What you after TECHII for Mark?
Swapped the battery, hopefully it's a dying cell that was causing the sluggish starting, certainly the charging from the Alternator looks OK.
Unpacked a box containing wishbones and rear adjusters  :) (Cheers Jason @ AGP) So I guess next week i'll have to pop into the trusty MOT station I use end get them to press the front bushes out as i'll re-use the poly's from the existing ones....
minifreek
Its got opps all to do with the geometry....
Quote from: 4x4 on 10 July 2015, 21:53:27
^^^^^^^^^^^^ this :)
D.I.L.L.I.G.A.F...
amba
Replaced A/C condenser on Youngest daughters Fiesta TDCI so she will get it regassed in the morning and hopefully grand-daughter will now be nice and chilled  8)
Spent the afternoon stripping the Galaxy to get the turbo out.
Haynes tells us to balance the engine on a piece of wood and a trolley jack then pull the engine forward to access the turbo - er, no thanks  ::)
Got the inlet manifold, EGR and EGR heat exchanger out without snapping any seized studs :) Tomorrows task is to get the exhaust manifold and turbo out, split it so I can free up the vanes then put it all back together - simples (I hope) ::)
mka306
Quote from: RobG on 11 July 2015, 18:05:57
Just to clear EML codes from my car, i've had p0300, p0305 & p430, just want to make sure it's all clear Rog.
