Lagondanet
Quote from: Harris K Telemacher on 11 August 2015, 23:00:44
Quote from: Lagondanet on 11 August 2015, 21:59:38
Latest. On way back from London 90-95 degrees. Low coolant light came on. At home, engine off, expansion tank dropped 50%. No apparent leaks other than seepage from cap?
New bottle and cap then  ;)
My second local Vx dealer said it was the cap (replaced) & that the tank is OK. No mention of HG. We shall see. Thanks for advice.  :y
steve6367
I got the stupid filter apart and didn't break it!  :y  ::)  :D
Then I thought I'd just take a look at the Estate - exactly the same solid as anything and to add to the fun the oil drain plug is also solid! Do garages put these things on as tight as they can for fun?! Time to stop and have some wine!
EMD
Whats that screw thing ? , mite need one of those to take the one off the 2.5 .
Omegatitis
steve6367
Brilliant is what it is! I tried with various chain / strap devices but just slipped. I used mole grips to just nip it up and it held firm  :y
It is this:
http://www.halfords.com/motoring-travel/tools-diy/tools-tool-kits/halfords-advanced-professional-oil-filter-removal-band
Lagondanet
Might get one to take the top off the Marmite jar.  :y
EMD
Quote from: steve6367 on 12 August 2015, 21:23:22
It is this:
Good bit of kit that  :y Are you converting to spin on now ? Just wondering as your housing was spinning because the locating tab had broken or something  :-\
Omegatitis
steve6367
Quote from: Lagondanet on 12 August 2015, 21:26:11
It will cope with that - held the body against my 18" breaker bar with me hanging off the end!
steve6367
#10957
Quote from: EMD on 12 August 2015, 21:29:55
It is this:
I'm not sure there is a location tab to be honest, but happy to be corrected?
They both seemed in perfect order so put them back on 45nm on the body nut and 15nm on the cap. Will see what happens in 6000 miles time. I had already ordered one spin on converter, but at £15 +vat even with TC I am not sure I need it.
Its one of those job that even if they stick again I can now do quickly with the tools I have.
EMD
Think ill get one from here though  :y
filter band
Will be handy for the spin on anyway  ;)
Omegatitis
steve6367
Quote from: EMD on 12 August 2015, 21:39:42
filter band
Good price  :y
Unfortunately I was in that I need it now situation so Halfords won!
Started clearing the decks ready for a rad/condenser swap and found a couple of crusty bits... Two holes later and I am done for the day. Will need to break out the grinder tomorrow in order to remove the self levelling pump bracket.
Christ alone knows what the previous owner did or didn't do to the car, but he obviously parked it in the Mancchester Ship canal ::)
ronnyd
It is this:
Just read the reviews on the Halfords one, very mixed to say the least. I think i will stick to my ancient chain one as there is a fair amount of room on a Desmond.
steve6367
Quote from: ronnyd on 12 August 2015, 22:57:20
It is this:
May just be me, but I could not get either the socket or handle chain type to grip on mine - the tool linked worked perfectly. (with some gentle tightening with mole grips)
EMD
Just cut up an irmy front bumper in to 4 bits with a jigsaw
;D
Omegatitis
Shackeng
Replaced the fubarred TD intercooler fan with a SH one which works well through my manually switched cct. While doing so I put some fine chicken wire in the rubber intake to stop leaves etc. blocking the fan, which probably caused the failure. :y
