1 Member and 0 Guests are viewing this topic.
ted_one
Unable to find a Bosch MAF sensor at the moment so used some air sensor cleaner,refitted,cleared the MIL, and the car's running sweet as a nut again (don't know how long for tho' ::))
Not my car, but a colleague's that I promised to service... A rather Renault.... And some muppet had stripped all the undertray securing bolts. :-X
How do I get myself into these situations? ::)
flyer 0712
Fitted dark grey leather cdx interior seats to the old bus today and they look good.. :y
EMD
Post lady delivered a louder reversing beeper /buzzer sensor
thingie as old one sounds like a strangled cat  :D Got to fit that  ::)
Omegatitis
I really should start the Bullet. Its not moved since being picked up from MOT place  :-[
New MOT today for the Desmond being sold :)
BazaJT
Walked past it,ignored it.Given the weather forecast and the fact that the six nations has kicked off today the chances of my fitting the ecu sender and temp. sender into the coolant bridge are pretty near zero.Car hasn't turned a wheel since November!
DrAndyB
Fitted new GM Headlight covers  :y  After discovering one must have 'fell off' last week as there was only 1 on the car when I washed her  :-[ (don't remember running over that one  :o)
Ahh, and remembered to "GENTLY CLOSE BONNET" after fitting the new ones  ;D ;D ;D (Instuctions even remind you 'Do not slam bonnet' !
Drove it almost to Bridport, before the water pump pulley made a bid for freedom. >:(
b4ndit
Quote from: DrAndyB on 06 February 2016, 16:18:59
they look very nice :y :y
Quote from: Kevin Wood on 06 February 2016, 17:38:27
That won't end well :o
The Omega or the go-kart :-\
Quote from: Harris K Telemacher on 06 February 2016, 17:48:21
The Omega. Water pump seal has failed too. Not sure of the sequence of events, but 2 pump pulley bolts have disappeared, and one has sheared off. Guessing 2 worked loose and fell off, then the final one eventually gave way. Pump shaft feels fine, so thinking there might have been some local coolant boiling after the failure that did for the seal. It got shut down as soon as I felt the PAS go, then coasted into a side road and Green Flag. ::)
Have bicycle, so motor factors on Monday morning. Hope it stops ssipping down. :(
Weekend in the pub then... Every cloud and all that ::)
DrAndyB
Quote from: b4ndit on 06 February 2016, 17:40:38
Cheers.  Always had them on the car, and I have owned my MFL 2.5V6 CDX Manual from new  :y. I suspect they have helped protect against the dreaded UV which causes most to develop the usual "Cataracts" to then trigger the various grades of wet and dry being applied with elbow grease and plenty of water.
Quote from: Harris K Telemacher on 06 February 2016, 18:10:32
Pub doesn't do food, and occasionally even beer is too much trouble. :(
