EMD
Took a Mk3 Cavalier for a test drive , owner would not budge on the price so walked away  :(
Omegatitis
Quote from: EMD on 09 April 2016, 18:13:57
If a car is advertised at a certain price, why do you expect to get a discount?
I've just been to the Chinese. It cost £21.30, but I didn't offer £20.
EMD
Quote from: STEMO on 09 April 2016, 18:36:13
Because he didnt tell me about it needing new :
Front brake discs
Rear tyres
2 rear lenses
A dent in the rear door
Weeping rocker cover and looked like the oil hadnt been changed in 10 yrs  ::)
Omegatitis
Shackeng
I would have. ::) I bought a SH desk chair last week, in the local Office shop at £25, offered £20, and took it away. :y
Quote from: EMD on 09 April 2016, 18:40:32
Front brake discs
Rear tyres
2 rear lenses
And you took it for a test drive? You're lucky to be alive.  ::)
Thought I'd get lots done this weekend - I was aiming to have the (old Jag) wheels on the kit car.
Fell at the first and second hurdles - I can't find the old Jag wheel nuts (or any M12x1.25 nuts, in fact!) >:(
Then realised I've never actually put a front hub on a car that uses old fashioned taper bearings so googled how to set the end float.. tried all sorts of instructions (most people just say "seat the bearings, back it off, finger tight till you can feel just a hair of play") and I think what I settled on is actually likely "too tight" so it'll be backed off again tomorrow to try and hit the magic 0.001-0.003" of end float the book describes.
So much for rolling this weekend...
Fitted all 4 of the older 'flat' style Elite alloys I had in the garage, with Kumho KU39's on them to the 3.2, vast, vast improvement over the shitty Nexens. Very happy  :)
Also had pair of Kumho KH31's fitted to the rear of the 2.2, as the rears were shot legally speaking.
Kumho's all around  :D
Quote from: aaronjb on 09 April 2016, 19:11:15
Rally Design stock various M12x1.25 wheelnuts for about £1 each if that helps. You won't get them this weekend though ;D
Quote from: Nick W on 09 April 2016, 19:34:40
Ta Nick!  :y
I wish I'd gone looking for them earlier now so I'd have been prepared.. ah well :)
jimbo125
Yep sounds about right, had an Opel manta many years ago tighten hub nut to a certain torque value and then carefully slackennut until a 4" feeler gauge could be dragged through between washer and bearing. The tricky bit castlated nut so had to be careful of where the hole for the split pin was.
2.5V6 Had it since 2002, what a beast, worth the time and effort to keep it road worthy. Vauxhall bring them back!!! Laser timing kit for OOF member hire
joff
Drop links and fuel filter on the little van, and a 12 hours night shift to go :'(
Shackeng
Quote from: joff on 10 April 2016, 12:04:09
Which one's that? :-\
minifreek
Fitted a better set of reversing sensors...
Removed the rear seats and trim, fitted soundproof stuff, fitted new rear components...
Currently in the middle of rewiring the rear to accomodate the new speakers and amplifier :y
Removed all BOSE stuff when I first got my Miggy, around 2 1/2 years ago... only because the BOSE H/U was shagged and all speakers needed replaceing.....
Should be back together later....
D.I.L.L.I.G.A.F...
Calif-Native
Flushed cooling system and loaded it with Toyota Antifreeze/Coolant for max protection.  Used the concentrated "Long Life Coolant" due to it not having silicates, borates, net gelling and no seal issues.  I prefer the Ethylene Glycol based stuff over DEX cool and have seen very long water pump service in my other GM cars with this Toyota product.   Finished the coil pack relocation this past week.  Next project is the Oil exchanger bypass to external cooler.
Trusting a person's word is like a bank account, once emptied and left unreplenished, you have moral bankruptcy........
Not to car, but to garage - tidied up following have to get one of my roller cabs replaced (which mean the contents of the top and step up boxes were scattered all over the place ;D).
Hoovered garage floor again, managed to pull up a lot of paint by the door, looks like water has crept under the paint somehow.  Also noticed how badly I'd chipped the floor near one of the workbenches.  Looks like come summer, I'll need to drop another coat on it.
