Tick Tock
Made a start on cleaning the sills after removing the covers, but the job stalled when I wasn't sure whether to remove the donut bolt on the back end. Now I know (or so I've been reliably informed) I'll continue on the next sunny day.
Whilst the rear end was up on the ramp, decided to clean and grease the brake pipes...... that was a job in itself, and wouldn't relish the thought of having to replace them with the way they duck and dive all over the place.  :'(
Omega 2.5 V6 Facelift Estate.
YZ250
Quote from: TheBoy on 03 April 2016, 18:54:15
Quote from: tunnie on 03 April 2016, 10:58:37
Quote from: YZ250 on 03 April 2016, 09:49:39
Quote from: TheBoy on 03 April 2016, 08:33:18
Quote from: tunnie on 03 April 2016, 01:37:23
Quote from: YZ250 on 02 April 2016, 12:20:28
Removed ALL four wheels to get them sorted as I'm fed up with pumping the tyres up every day. D
How are you getting them repaired?
Standard refurb as a guess
Yep, standard refurb.  :y Dipped, stripped, checked for any cracks etc and refurbed like for like colour wise. The outer side of the wheels looked ok but the inner rim had flaked badly. The bead seal had been dressed previously but they were becoming troublesome again.  I'm hoping this cures it.  :-\
Two fronts on mine, one in particular looses pressure. I find it can be fine then all of a sudden loose 5 PSI. I think it depends on where it's parked on which point of the wheel.  :-\
Where are you having it done if you don't mind me asking? Also rough cost?
I really need to consider sorting 3.2's
It could simply be that the wheels weren't properly cleaned when tyres were last changed, so you get a leak at the rim.
But a refurb is normally about £170 for 4 at the place I used for simple wheels, or for the chav wheels, £45 per wheel, plus £10 per wheel if it needs repair (out of round, minor welding etc) at a place near work (the headquarters of a national refurber) if I drop off/pick up.  Add extra if you need tyres removing and/or disposing.
Similar money to what I'm paying (£48 including vat, as discussed with Tunnie via pm  :y).  I did enquire at Pristine Wheels in MK as they seem to have a decent reputation but their reply was "To refurb these will be £68 each plus VAT and £20 each to remove/refit tyres" so I gave them a miss.
I also had WIM remove and re-sit the tyres, I still had same problem. So a refurb is way to go I think for them.
Whenever I have my tyres changed, I always ask, and watch them do it, for a good wire brushing. Not that any of my wheels will ever be old enough to need it.  :P ;D
jimbo125
Number two head cleaned, valves relaped and new valve seals fitted oh and exhaust valves cleaned some what carbonised ;D
2.5V6 Had it since 2002, what a beast, worth the time and effort to keep it road worthy. Vauxhall bring them back!!! Laser timing kit for OOF member hire
Taken shortly before I put the second rear hub on.
Front hubs to go on the spindles once my order of M6 button heads turns up to secure the splash shields behind the hubs, rear wheels can go on just as soon as I manage to split the driveshafts (needed to order bigger circlip pliers!).
Quote from: aaronjb on 04 April 2016, 09:57:47
It's starting to look like a car!!! :D
Drove it to work (2.2) realised when I got there it is green, not muck coloured grey. It needed it's first wash of the year since about September  ;D
joff
Quote from: tunnie on 03 April 2016, 19:31:20
Just taken mine in for refurb today, total bill will be £245 that's for 4 wheels normal silver late elite style
Quote from: joff on 04 April 2016, 14:29:59
Same alloys as me, also have feeling YZ250 too? Does appear to affect later Elite alloys more  :-\
danzigfan
danzigfan
Used the 3M kit today, it makes difference :y
YZ250
Quote from: tunnie on 04 April 2016, 14:49:48
Yep, late Elite alloys.  :y
2boxerdogs
Fitted new front screen washer pump in the 4x4 pump £39.00 from Hyundai took about 90 mins to fit, then   took it to EMG & had the air con re gassed ready for the heatwave that's coming 😀 😀 😀
raywilb
I cleaned the intake manifold on my 2.2 dti . I started at 10.30am and was all clued up by 2pm. I had a real trepidation about doing the job, though a bit fiddly at times it went ok. when off, to be fair it was ok, a bit sooty but not too bad at all. both parts of intake only took about 10mins at the most to clean. the intake manifold only had one flap in situ & when manually working the actuator that stuck slightly when shut. I got rid of it. regards trying to start it wasn't too bad I never had to crack a few pipes or do anything to bleed the system just an extra battery to assist the cranking.  :y
