baggedestate
cleaned mine ready for tunerfest tomorrow :)
neil74
Finally changed the rear pads as they were down to the backing plates.
Took heat shield off, that sits above the cat on the 2.2, that should stop it rattling  ::)
ted_one
Washed the R8 and then it bloody rained ...as usual, ::) the weather here is well and truly fubard,only had one bbq and one evening when we sat out and had a couple of beers.Thinking about a move to warmer climes if this carries on :y
minifreek
Rebuilt the engine with added oomph - hopefully...
Have changed the headers for later type, changed the 2 G cams that was inlet for A cams :y ditched the SAI system, removed the bit of exhaust downpipes that needed removing, removed the AC pump only to find that the shorter belt I have, is too ruddy short, so will need to re-install the AC pump LOL
Had to completely remove the exhaust system, which in itself is a task as its an all-in-one system with no joins, so is a bit of an effort to get it off the car.... should be interesting tomorrow when I come to put it back on...
Am awaiting another radiator as a replacement for the 1 that wa bough new t'other week but has burst, so even if it was ready to start, I won't be able to coz the oil pump would just spray oil everywhere.... so its now a waiting game...
I wouldn't mind but we're supposed to be going away next weekend, looks like we'll be going in my classic Mini instead... that gonna be a wild ride LOL
D.I.L.L.I.G.A.F...
ffcgary1
Fitted 4 new avon zv5 225 55 16 tyres to the tourer, got a bargin at £55 per corner, never had avon tyres so going to see how they fair over the coming months / years.
Replacement sevo pipe to be fitted tomorrow, and another oil,oil filter / air filter change mid week before our trip to theipval next week for the somme commemorations/ holiday.
if i can fit it in, pads and discs change as well.
Jaguar XJ6
Quote from: ffcgary1 on 18 June 2016, 21:20:45
Fitted 4 new avon zv5 225 55 16 tyres to the tourer, got a bargin at £55 per corner, never had avon tyres so going to see how they fair over the coming months / years.well.
I had them on the rear of the tractor.  Due to the excellent feedback, it was a hoot for about 4k, then the threads were hanging out of them  :-[
I hope you fair better with durability, which if you don't drive like a complete loon, you will :y
Changed the oil on the Bullet, as it was sounding like a bag of nails.  I'd been a bit lax, working on the principle that as it operated on the constant loss system.....   :-[  :-[  :-[
Changed the rear pads on the Bullet. Yet again.  With better rear tyres, I was hoping for better pad durability on the back, but seems not to be the case.  One of the pads was down to the metal, others had about 3mm on, so exercised the calipers whilst there.
Then re-removed the OSR pads when I found I had bits left over, and reassembled with the shims in ;D  :-[
Found the battlebus, and changed the oil on that as well, popped some electricity back in it, then re-abandoned it.
Was going to change the oil in TBE, as that's not far off due, but didn't have enough oil.  Need to get my TC registered at a dealer, as my old dealer no longer does TC  :'(
All on Project II, Cleaned off flaking underseal from the N/S/F inner wing etc, rust converted and undersealed, rust converted engine sump, replaced missing washer pumps and flushed washer bottle through, swapped front bumper for MV6 bumper and cleaned and rust converted the surface rust patches on the crash bar then fitted new front number plate.
joff
No work on cars as on nights at the moment, 5x12 hour shifts done with 3 to go then a quick vote before bed on Thursday. Don't think the Elite has been off the drive since I got back from sunny Scotland on the 3rd June, if it has it must have been a short trip as I have to put some fuel in it soon ::) little van does 50mpg so slummmmming it at the moment :y
Project II, relocated Bose amp to side, fitted rear blind which has now decided to not work  >:(
Migv6 le Frog Fan
Had a nasty misfire appear on Saturday. Found a cracked coil pack and plug wells full of water. Pouring water on the screen showed it was running straight through the scuttle panel join and all over the n/s of the engine.
Today removed scuttle (found most of the fasteners missing) and replaced it with a very nice spare scuttle I have had in the shed for a few years. Sealed the join and wiper spindle thingys with silicon sealant. Used all but one of my spare fasteners putting it back together.
All job jobbed now.
Back to doing the little chips & scratches tomorrow - if it doesn't rain.  ::)
Got Big Blue a 13 month MOT with no advisories :)
Steve B
Replaced drivers side central locking motor on the 2.2 in a record time for me 2 hours  ;D ;D ;D
annihilator
crossed my fingers and took off the elite's sill cover and was pleasantly surprised to find this
only a tiny bit of surface rust in a few places otherwise spotless,if only my previous MK2 Astra had been the same.
John.
