annihilator
took the the passenger side off today and although the surface rust patches were larger (road camber?) still no rot or anything to worry about.
John.
jimbo125
They know how to build them in germany :y and to think people slag the miggy off tut tut, treat and prevent further corrosion. You going to wax sills inside?
2.5V6 Had it since 2002, what a beast, worth the time and effort to keep it road worthy. Vauxhall bring them back!!! Laser timing kit for OOF member hire
annihilator
Yeah,will do the business on them.
John.
Project II - Undersealed O/S/F wheel arch, re-attached backbox heatshield with the help of some big washers, cleaned and greased rear brake pipes and fitted park pilot ECU and loom (left the sensors as bumper needs to be replaced).
jimbo125
Quote from: VXL V6 on 23 June 2016, 19:23:58
Should this not be in "what have you done to your car today" section? ;D ;D ;D
Quote from: jimbo125 on 24 June 2016, 14:57:58
Project II - Fitted modified NCDC2013 and CID and repaired spare key with new switches and case.
baggedestate
fitted new rear spacers gave rear wheels full clean inside and out before the rain hit
minifreek
Checked oil and water, just keeping an eye on them after the HG's got changed....
Everything fine at the moment, can't do much anyway coz we away in our tintent....  have my RAC card :)
D.I.L.L.I.G.A.F...
So, so, so very close to running out of fuel in Battlebus.  Arse cheeks fully clenched as it started to miss. It took 57.8l to 2nd click of pump.
Need to check tank size for a Zaffy-A
Quote from: TheBoy on 25 June 2016, 21:35:52
58 litres...
Must try harder ::)
Quote from: Doctor Gollum on 25 June 2016, 21:39:03
58 litres...
Must try harder ::)
The range warning on the GID was annoying me (and I couldn't then see the time), so I acknowledged/cancelled it.  The yellow fuel light is not bright enough.
Is it 58l tank? :o.  That's cutting it a bit too fine, even by my standards.
Quote from: TheBoy on 25 June 2016, 21:42:36
58 litres...
Must try harder ::)
Not really... Don't think you've actually run out completely for a while now ::)
