Gained confidence with VW, jacked and on stands today. Inspected rear pads, needs new ones soon. Might fit new discs too, looks all straight forward to change. Shocks look easy, 3 bolts, 2 at top one at the bottom.
First VCDS scans, had to double up my USB extension cable for it reach the car from my garage PC.
Also stuck some new Bosch Aero wiper blades on it.
citroenguy
Quote from: ronnyd on 06 November 2016, 15:59:09
Quote from: citroenguy on 06 November 2016, 14:21:32
Changed the aux belt and washed it  :)
Why did you wash the aux belt? :D
Because there were too many wine stains on it  :D
124k on the C5
I like Omegas Senators and all other big 90´s euro saloons.
Previous motors: 3x Rover 600s, Citroën ZX, Volvo 850
Quote from: tunnie on 06 November 2016, 21:05:01
If doing anything other than reading, can you get car closer.  I think even VCDS  still uses an element of bit bashing, which I suspect might cock up if you're out of spec on the USB side.
How long you talking?
1x5m and 1x4m I think, I've only done reading so far. Full scan, the dived into Engine stuff and read loads of "extensions" I think, tapping tick boxes brought back data for each item. Tapped about 6 for loads of info on the DPF.
Plan on weekly checks to monitor how DPF does, but appears fine over last 3k. But I want to monitor how quickly the soot builds up and how much ash that generates.
The hex-com dongle has a microprocessor in it (powered from the car) that talks to the k-line(s) so I don't think a long USB lead will hurt comms to the car.
Whether the usb comms are affected may be a different matter though.
Migv6 le Frog Fan
Changed the stat. Dropped the bastid bolt, due to cold fingers. Took about an hour to get it out from under the a/c compressor.
Took the n/s camcover off and cleaned everything up, ready to fit new camcover and gasket tomorrow if the weather stays dry.
Was hoping to do both jobs this afternoon, but the cold weather and light starting to go convinced me to stop.
Experience tells me if I try to rush it to finish the job quickly, something will go wrong.
I've just spent 20 minutes staring at the broken and new air fittings, and still haven't decided how to accommodate the differences because my feet are so cold.
I'm going  early, and she can shout at me tomorrow.
2boxerdogs
Had the Merc valeted , excellent job plenty of wax on it now tucked up in the garage.
I'm sporting too many injuries, so haven't even ventured out.
Quote from: TheBoy on 08 November 2016, 17:42:14
Been giving the wife some lip again?
Quote from: STEMO on 08 November 2016, 17:45:31
I will do in a minute - I've been laying on the sofa for ages waiting for a cuppa...
TD
Quote from: TheBoy on 08 November 2016, 18:07:13
Makes a change from being rooted in the bath  ::) ;D
Quote from: TD on 08 November 2016, 18:52:41
I've never been rooted in the bath. What's it like?   :-*
ronnyd
Quote from: STEMO on 08 November 2016, 19:24:03
Ask ya avatar :P
Splashy
