Quote from: Migv6 on 11 November 2016, 15:17:22
Where do I send the cigar Kevin ?  :D
A squirt of WD, left it an hour or so, plugged the connector in and fired it up. All back to normal.  :y
I love it when a plan comes together. :y
Had the Chinese ditch finders replaced with the Accelerator winters... Worked out at £51 per corner, fitted  8)
Also reset the Abs light, looking like osr sensor :-\ easy enough to change if it comes back...
Migv6 le Frog Fan
Fitted a new (to me) climate panel. Looks much better, but the headunit now sits about 2mm proud of the dash which is annoying.
Have pushed it as hard as I dare but it doesn't want to go fully home for some reason.  :-\
Front hub changed, not a bad job all in all...
Quote from: Migv6 on 12 November 2016, 16:48:49
Is it's cage a fully enclosed type, where connectros clip in cage (like FL Omegas)? In which case, check cage around connectors for distortion.
If not fully enclosed, its likely to be bundles of wires in the way stopping it fully seating back.
Car? I haven't used it for days.
Hopefully it's still outside somewhere ;D
Migv6 le Frog Fan
Quote from: TheBoy on 12 November 2016, 17:31:21
NCDC 2013.  :y...............was a real struggle to pullthe headunit out, but I suppose I will have to bite the bullet at some point and do it again. Might buy some better quality removal tools first tough.
Changed a wheen at the side of the road in Crewe, great fun.
And this morning ordered 2 new tyres...always sommat.
BazaJT
Managed to get bonnet open,refitted battery,inflated rear tyres.Then drove it[first time it's turned a wheel since last November!]quarter mile to lock up garage.Happily it just fits in[this was my main worry when renting the garage]so it will now hibernate until warmer weather returns next year when I'll fit the new oil cooler and other bits I've got for cooling system.
Quote from: Migv6 on 12 November 2016, 18:27:08
Does FM work? Is Satnav getting a signal?
On Omegas, its not uncommon for one of the antenna socket holders to distort.
Bought it a battery... Failed to start earlier... After a decent run following a jump start it contained a measly 12.3 volts...
It was a Bmw battery, and whilst I am not naive enough to believe that it was original, I have no idea when it was fitted.
Alternator is working as advertised using Kevins excellent guide, so confident that the battery is on its way out.
powerslinky
Fitted the new late MV6/Elite alloys that I aquired from James, to the CDX estate.
Very pleased with my DIY refurbing in Star Silver . .   ;) ;)
IMO the car looks much more appealing to the eye with these wheels on   :P :P
Started to  give it a light cut & polish . .  managed roof, tailgate, rear bumper, all the passenger side & the front bumper.  That leaves just the drivers side front wing & both doors for next weekend :y     oh & a quick refurb of the black bits 8) 8)
Migv6 le Frog Fan
Refitted scuttle panel & wipers. sealing scuttle (hopefully) in the process.
During this weeks work I have lost a wiper cap and plenum cap  ::) Which means I have to root through the boxes of spares in the hope of finding replacements.
Quote from: Migv6 on 13 November 2016, 21:01:52
Just remove the others. Problem solved. For ever.
Migv6 le Frog Fan
Quote from: TheBoy on 13 November 2016, 16:35:11
Everything works fine, it just sits slightly proud of where it should be.
