Zirfeld
Omegas foam rubber is dry at last.  So I removed driver`s seat to assemble it again. Also the nice cleaned carpet went to it`s place. At last I fitted all plastic panels on drivers side.
I am not forced to drive an old Omega. I simply like it.
MikeDundee
Nothing yet but need to change the main beam bulbs before MOT next month, plan on doing that today, fixed the windscreen seal that auto glass replaced when they changed the front windscreen for the third time, that came off both sides while driving at low speed on the motorway, did not realise where this weird like water drainage noise coming from the back of the speedometer etc., Then after stopping for a break on the M1 after driving all the way down from Dundee, saw the strip was loose (the cause of the noise :-X)
Howdo, Mike?
Yesterday fettled the "roller skate" back into action and took it for a short blat following its hibernation. Seems to be business as usual. :)
MikeDundee
Quote from: Kevin Wood on 17 April 2017, 09:06:32
Howdo, Mike?
Yes all good Kevin, car still going strong :y, had a good run up and back to Dundee Thursday 7 April came back down on 11th managed to avoid the 3/4 hr delay on the M6 due to the burning bus by cutting across M62 to Leeds then back down M1 :y, and only spotted one omega and that was on the way up :-X
MikeDundee
Just replaced both main beam bulbs :y, done well to last 147k, unless they were replaced before I bought the car which I doubt very much ::)
Poked my finger through the sill......  :(
Quote from: STEMO on 17 April 2017, 17:42:24
Quote from: Sir Tigger QC on 17 April 2017, 17:36:18
Did you pull out a plum?
Kick a man when he's down.  :'(
Quote from: Sir Tigger QC on 17 April 2017, 20:15:12
You choose to drive own an omega, no one forces you.  :P
Quote from: STEMO on 17 April 2017, 20:30:58
Not for much longer it seems.  ::)
Quote from: Sir Tigger QC on 17 April 2017, 20:32:47
Oh well.....all good things must come to an end.  ;D
My issue was:
1) I can't weld so no DIY repair.
2) If the sills are shot, what else is about to rust to the point of cutting and welding requires fixing.  :'(
Quote from: tunnie on 17 April 2017, 20:50:44
My issue was:
1. Not strictly true...
2. Nothing that can't be addressed... See 1.
My issue was:
I disagree.  Certainly my sills were shot. I've even got the replacement sills in Hornby's garage (based on the fact I'm not good at welding used metal).
But I certainly lack the skills to do bodywork repairs and spraying, which was the underlying concern I had with mine, even if I fixed the gearbox/sills/aircon, I'd still likely fail next MOT on perforated rear wings.
Zirfeld
