Tick Tock
Fired up the CD estate today which had been stood still since last August, gave it a good wash and cleaned all the moss and algae off it, not that it's going anywhere.......  no MOT, and probably worth no more than £100, I've got the space to store it and probably worth more to me as a source of spare parts to keep the CDX going, should that day arise.
Particular attention paid to the lower door seals, and keeping any rot at bay, even though there's some rust coming through on the rear arches. When we get some decent weather, I may just take the sill covers off to see if it might see another day on the road, but for now it's going nowhere.  :'(
Omega 2.5 V6 Facelift Estate.
Zirfeld
Hi Sir Tigger
Lahr is a sleepy little town near the French border. But nice little hotels - not expensive. Beer is better taken from Northern Germany, my real hometown - Bremen. Here around is wine country, because Lahr belongs to the warmest corner of Germany. Sometimes a little mediterranean weather.
When you need a party zone, you have to go 30 miles south on the A5 (no speed limit  :D) to Freiburg.
If some oof`ers came over here, I can offer a little "Omega welding workshop" over the weekend.
Rolf
I am not forced to drive an old Omega. I simply like it.
Zirfeld
#14162
Hi Tick Tock
Have to do the same over the near future on my 98 saloon. The car is not in use since November 2016, but pretty welded with new Tuev (until 6/18), new brakes and new front suspension. I will do registration next year.
Shackeng
MOT on the 3.2 Elite, Passed with no advisories. Will be sold soon. :(
EMD
It growls and snorts , quite addictive . Just need the free flow stainless cat back to go on  :)
Omegatitis
danzigfan
Replaced "wrong" driver side cam cover gasket...using Vectra's gasket... :-X I know I'm going to hell for this :P , a bit of fidelling because half moons are added from Omega's gasket but it holds...for now at least. I had enough of leaking directly on to exhaust manifold
78bex
Jacked up the near side front & removed the road wheel, gonna check the front pads for wear
Instantly noticed the brake disc was revolving on the hub slightly
No sign of the disc securing screw  ???
Scratchin my head now, thinking it can`t have just dropped off it must be in the .......
......turn around behind me & it`s sitting there in a little pocket cast into the wheel  ;D ;D
EMD
Cleaned the wheels and thought about washing it  ::) Taking it to the car wash tomorrow  ;D
Omegatitis
Zirfeld
#14168
Removed the inner arch front cover, rear left side  :-\
Plenty of work underneath  ;)
Migv6 le Frog Fan
Just gave it a good wash and then dried it properly - like drying a baby. gently with microfiber towels.
Quote from: Migv6 on 22 April 2017, 17:16:16
Dried it properly with microfibre towels? How is that properly? I use beer: chuck a couple of buckets of soapy water over the car, then a couple of clear water, open a beer and let the sun dry it. Much, much easier ;)
Migv6 le Frog Fan
That's how I wash the 190, as its paintwork is beyond help. The omega is still shiny shiny though, so I try to keep it that way.
78bex
Quote from: 78bex on 21 April 2017, 23:05:30
Front pads are fine, but notice some corrosion forming around the inner wing welded strap
Spin off the corrosion & paint on some Birchwood Casey rust treatment.
Nitric acid mix & highly corrosive, but the rusted area starts to foam up niceley
squirt on some isoprop to wash off the tratment & it air dries real quick.
paint on Red oxide/zinc & I`ll do the other side tomorrow  :y
Started to take more bits off MV6, but thwarted quickly by virtue of Mrs TB's car booty shite all piled up in front of my tool chests ;D
Load it all into the bullet and ring someone to collect it... :D
