(about a week ago) Broke it. Bugger.
TD
Quote from: RumpelStiltSkin on 06 April 2017, 18:08:27
Buy a Ford.....you know you want to  ;)
Quote from: TD on 06 April 2017, 18:31:36
Its replacement already acquired ;)
Quote from: tunnie on 06 April 2017, 20:15:18
Quote from: RumpelStiltSkin on 06 April 2017, 18:34:55
Spill the beans then  :)
On this forum? Ha! We've got to play guessing games till next week yet.
Migv6 le Frog Fan
Removed n/s/f suspension leg. Built up new one to replace it, ready to fit in the morning. Working over the weekend, so hoping to get the o/s done on Monday.
Viral_Jim
Took the old girl for an MOT, passed with no advisories... again  8)
They also changed the fuel filter which I forgot to do - senility setting in early.  ???
mantaray
Replaced both front wishbones on the V6, found old ones had poly bushes but didn't have time to swop them over to new ones. Is it worth doing?
2.6 CDX Auto Estate,
71 Opel Manta A Series 2.5 V6
mantaray
Quote from: mantaray on 07 April 2017, 14:01:22
Only the front wishbone bush was poly,(horizontal bush) are rear bushes (virtical) available in poly?
There is a company in Poland producing them.
From experience, I am going to say 'No'... :-X
Tweaked the handbrake, now works on both sides ::)
Only six advisories to go... :D
Zirfeld
I am not forced to drive an old Omega. I simply like it.
Investigated the cause of the non working headlight washers on the 530d (E39), so removed offside wheel arch liner to find the pipe was split and disconnected.  It's plastic and has gone brittle, so I replaced a length with rubber pipe but then managed to break another piece of pipe further down the line, so I will replumb the whole system when I get more pipe.  ::)
I also noticed that the shock absorber is leaking and the MOT's due next month!  ::)
I've got 3 cars and none of them are any bloody good!  :o  ::)  ;D
