Drove it to the land of the webbed feet, using back roads due to A14 mess today.
A 2t exec saloon should not be able to go round corners like that.
Migv6 le Frog Fan
Your suitable impressed then ? I might buy one in 10years time when they are sub £2k.  :y :D
Lagondanet
Put a litre of coolant in. Let's see how far that gets.  ;)
paul l
Stripped spare door cards down, in readiness to give them a make over
2boxerdogs
Booked the Merc in for a custom made exhaust on the 27th saw a company on Car SOS TV programme John Ashley in Walsall & rang them very helpful and obviously keen on cars , will let you know how I get on.
paul l
Dropped car off at county diesels in Leicester, fed up of the wheezing noise. Hopefully they`ll find the problem
Quote from: paul l on 11 July 2017, 15:32:16
Do you smoke?
paul l
TD
I'll bet you 1p its blocked breathers or summat else  ;D
Quote from: Migv6 on 10 July 2017, 22:24:18
Not with the economy on a run like that. Opps.
paul l
Quote from: TD on 11 July 2017, 17:53:53
I'm hoping so, its driving me up the wall, checked and rechecked but very limited on what you can do on a driveway without a pressure test
TD
Quote from: TheBoy on 11 July 2017, 18:15:26
Are you saying a 2ton Jag with a 3ltr diesel engine carnt manage 50mpg average..... :-\ ;D
Buy a 1.6ltr diesel Ford....that can  ;D
Quote from: paul l on 11 July 2017, 18:26:10
It can only really be the inlet track
paul l
And the inlet manifold gasket it was  :y new one now fitted and wheeze free, first Tim since owning the car.
Migv6 le Frog Fan
Ben touching up some small scratches and stonechips. Tedious job, and the more you look the more you find.  ::)
