Quote from: aaronjb on 19 July 2017, 10:01:56
Reg was an easy (and cheap) fix on the 645 - if you ignore the three days it took to liberate the alternator to get at the regulator ;D a problem you're unlikely to have on yours :y
Maf and air filter housing out should do it ;)
Quote from: Doctor Gollum on 18 July 2017, 21:28:42
Voltage 13.4 at idle, drops to 12 with a load applied and gradually creeps back to 13.2 with some revs...
Looks like the alternator is getting lazy, so if I am stuck with it any longer, then it will be at least a new regulator and the Abs ecu reconfig...
Sounds more rectifier diodes with those symptoms to be honest
Quote from: Fuse 19 on 19 July 2017, 10:58:03
Are they not part of the regulator assembly :-\
Auto Addict
Drove it like there's no tomorrow at 43 mph!
I like red cars
Quote from: Auto Addict on 19 July 2017, 15:06:48
You'd better drive it to the dealer so they can 'fix' it, or you'll be poisoning all of your fellow campers when you park up on the farmers field.  ;D
On second thoughts...... ::)
Quote from: Doctor Gollum on 19 July 2017, 11:20:41
Sadly not, separate items.
Quote from: Fuse 19 on 19 July 2017, 15:15:16
Ah, yes... Refurb for £45-50, or new for £100...
That's to say parts for refurb or complete alternator.
Quote from: Doctor Gollum on 19 July 2017, 15:30:20
Crikey, a new alternator for the 645 was >£500! At that price I'd buy a new one (if I was keeping the car)
Zirfeld
#14828
Replaced the right front door stopper. The inner holder was broken and banded. So I opened the inner door frame and removed the holder. Not easy. Welded in a 3 mm angle with holes for the original door stopper. Own construction, works perfect. At last I closed the repair window.
Everything works perfect now. The yellow plastic spacers are ordered and will complete the repair.
Left Side (drivers side) I did the same way two years ago. It still works perfect.
Rolf
By the way, 33°C today. Tropical day (Tmax over 30°C) number 18 this summer. Puhhh
I am not forced to drive an old Omega. I simply like it.
Another solid days work there :y
Don't worry about the heat, it will still be 25 outside when you fit your winter tyres :P
Zirfeld
Thanx Doc
I Think the "to do list" on my Caravan will became shorter every week. Tuev (MOT in UK) should be no Problem in September.
Rolf (the last fighter remains  ;) )
EMD
Stripping back 24 years of rust and paint from the front calipers  ::)
Omegatitis
2boxerdogs
Oil & Filter change on the Terracan.
neil74
My drivers door needs that repair too. and I also need to change the oil/filter etc as I've not touched it since I bought the car. and I need to get the welding done before the subframe drops out over a bump..
Zirfeld
#14834
Drivers door repair I did 2 years ago. It sill works perfect.
