Quote from: STEMO on 27 July 2017, 13:43:02
Quote from: Doctor Gollum on 27 July 2017, 13:19:01
Spent a leisurely half hour changing the alternator on the 525...
It works, and is shiny, but hasn't fixed the gearbox issue. Same codes still present >:(
Car can go as it is...
Caveat emptor.  ;D
Absokinglutely :D
Little trip to Serek's to have the HBV changed ... so .. just how does he do it in less than an hour and without the requirement of a single sticking plaster ???
Genius the man is .. :)
Also discussed the next "little" job he's going to do ... all day one that "might" run into two if things go badly...  :(
Drove it. For the first time since last week.
neil74
haven't driven mine since Saturday as it leaks oil now thanks to the shitty oil filter setup.
2boxerdogs
Had a stainless steel cat back exhaust fitted in Walsall today ( John Ashley Exxhausts ) on the Merc V8 sounds brilliant now.
Quote from: neil74 on 27 July 2017, 20:48:09
PM sent Neil.  :y
Was embarrassed into throwing some water over the big kitty by comments on the Serek thread.  Turns out kitty is black.
TD
Quote from: TheBoy on 28 July 2017, 18:29:44
Black is one of worst colours for showing dirt.....next time get a silver one...much better at hiding the dirt  :y
Quote from: TD on 28 July 2017, 18:34:22
Opti told me that there was nothing better than a black pussy.  But he did want me they can be dirty.
ronnyd
While i,ve never been a big fan of the gay gold colour of mine, (you can,t see it whilst you,re inside it :D) i must say it hides the crap very well. ;D
78bex
#14875
New windscreen Thursday afternoon & mot Friday & she`s only passed  :y :y
Advisory  : both rear shocks light misting.
She struggled to pass the emissions & my bloke say`s the cat is gettin lazy ???
I`ve noticed recently that the coolant temp reads lower now at around 80 c.  ???
I think my car is feelin her age a bit, but still only 52k miles on the clock
Quote from: ronnyd on 28 July 2017, 23:21:04
Even if you can't see the outside (that's what I say about the pig ugly arse of the Jaaaagggg), being a 51 plate, you are still borderline having the brown dash...   ...and brown steering wheel, that's like holding a turd ;D
Quote from: 78bex on 29 July 2017, 01:49:06
Change the stat and the shocks, and next time its due an MOT, give it a good thrashing beforehand for 20mins, then take straight to MOT and get them to do it immediately then (I always booked first appointment for the day for this very reason - even then he always grumbled he had to get the cat hot again).
Stat on 2.2 is nice and easy, and rear shocks on any Omega are straightforward - but if original, might need a decent bar to undo bottom bolt.
78bex
Quote from: TheBoy on 29 July 2017, 09:11:33
Yer will do. The stat was a pattern part & changed out when we did the water pump & cam belt 3 years ago. Never pays to use cheap parts does it  ::)
paul l
Airport run today, first time out in 10 days, 41pmg ave there and back, 5 up with suitcases too. All tucked away till needed
