YZ250
Finally got around to changing the rear brake pads. Nice easy little job that should take only a few minutes but I had to keep dodging the rain.  >:(
I'm sure they are the originals so with 4mm left at 93K it just goes to show what a careful steady driver I am.   :)
Quote from: YZ250 on 18 August 2017, 15:40:51
Just normal driving  :y
When I picked up the VW I noticed it had brand new front discs and pads, I'm not expecting to do anything on these for at least 50k, more like 80k  :)
Done 10k already and they look no different in depth on the pad.  :D
Quote from: steve6367 on 17 August 2017, 23:36:56
Quote from: TheBoy on 17 August 2017, 20:20:15
Correct, v8 is the last for GS8211 ECU :(.  It never got the extra refinements that the GS820 got for smoother changes and better change points.
At least you know you are on the best available for the 3.2 auto
Which Omegas has the GS820?
MFL and non DBW FL.
They are no interchangeable with different models.
ffcgary1
Washed it today for the first time in 10 months, i know i have been slacking!!!, still all shiney and clean now and next week i will wash again and polish it, MOT tuesday, then will look at getting the oil cooler changed as it is just showing a slight leak into the coolant bottle, ::) get it done sooner rather than later.
Jaguar XJ6
paul l
did a faultless and smooth 680 mile jaunt in the land barge over the weekend and returned 40.2 average mpg
Auto Addict
Washed & waxed Mrs AA's Astra, washed & waxed the Merc, knackered.
I like red cars
Tried to book it into BMW to reprogram the Abs ecu.
And subsequently failed...
Apparently £140 worth of computer time equates to needing the car all day >:( which means waiting four weeks until they have a courtesy car available. Wtf ???
ffcgary1
Well another mot passed with no issues, now to get the oil cooler and cambelt kit changed, passenger side cam cover leaking at rear so need to get that done at the same time. ::)
Jaguar XJ6
ffcgary1
Jaguar XJ6
#14949
ffcgary1
Jaguar XJ6
Quote from: Doctor Gollum on 21 August 2017, 21:55:00
Why didn't you send yours off to BBA Reman or similar for testing/repair?  :-\
If you factor in the cost of your replacement ecu + reprogramming, I wouldn't have thought the cost would have been much different.  :-\
Nearly got stuck in a car park in Cardiff this afternoon when suddenly I couldn't engage reverse gear in the Mundano!  :(
I managed to squeeze out and back onto the road and found a roadside parking space that I could drive into.  ::)  A bit of investigation showed that the plastic collar on the gear stick that prevents reverse gear being engaged without lifting the ring under the gearknob had become disengaged.  :-\
I managed to reattach it (sort of), but I'll need to do a permanent repair with a bit of wire or ducktape!  ::)
Quote from: Sir Tigger QC on 21 August 2017, 23:18:18
Possibly, but equally it should have long been SEP ::)
EMD
Got a nice bruise from the slipped coil spring clamp  :-[
Omegatitis
