Lagondanet
Migv6 le Frog Fan
Which option did you choose, to extinguish the light ?
Lagondanet
I did nothing other than play Purple Rain very loud. Good Bose speakers.  ;D
Keith ABS
  Not today but tomorrow evening, will be driving it to Harwich to board the ferry to Holland for a three day car show in Heeswijk, Dinther
Keith ABS
Dumped the Battlebus, picked up some non descript shitbox. VAG I think judging by dash layout, will check badge when I'm not suffering CBA.
Checked. Its a Golf. I'm trying to like it, but its a shitbox.
Does anyone know how to disable the annoying beeping every time you rev it over 2000rpm, as its getting on my tits?
Quote from: TheBoy on 09 September 2017, 12:42:35
Why dat den? Is it fitted with some sort of canal boat engine that doesn't like revving above that? Of is that to remind you that it's lying about its emissions? ;)
Quote from: Kevin Wood on 09 September 2017, 13:34:40
F knows. It just bongs away saying "speed too high", and another icon in the silly display (designed to distract drivers from looking where they are going, which explains the behaviour of most VW drivers) suggests changing up, but if you do that, the engine labours until it eventually stalls.
The tacho has redline at 6k, so assume its proper fuel, but designed for a lawnmower.
tigers_gonads
Quote from: TheBoy on 09 September 2017, 14:42:56
If its like the Skoda's, it will have different driving modes .....
If its got a sort mode, try using it  :y
tigers_gonads
Quote from: TheBoy on 10 September 2017, 11:19:12
How do I do dat den?
Depends which display you have in it
The 17 plate Octavia estate had a built in sat nav / dab unit / MFD
Iirc, the car had 3 settings for driving dynamics.
Eco / normal / sport.
Sport disabled the speed chime.
OR if you go through the driving settings and up the limit. I think the highest it will go is 100 mph.
If it has just the small display in between the clocks like we had on the polo hire cars, its menu, MFD then scroll down and untick the box  :y
Also could be a speed warning, you can adjust in the MID. I've set mine to 100mph, it will bing and light up when you reach that speed.
http://www.vwgenuineparts.co.uk/VW_speed_warning.shtml
Quote from: tunnie on 10 September 2017, 13:41:47
It only seems to do it as you approach 1400 rpm in 2nd and 2000 rpm in 3rd.  rather annoying PoS
Thanks TG and tunnie, turned off speed warnings, sanity returned.  Frikkin annoying.
