Replaced front headlamp levelling sensor. Might be able to see where I'm going now. :y
Quote from: aaronjb on 25 August 2017, 09:04:17
Quote from: tunnie on 24 August 2017, 20:34:15
Quote from: TheBoy on 24 August 2017, 18:23:14
Quote from: tunnie on 23 August 2017, 20:04:51
Quote from: TheBoy on 23 August 2017, 19:06:56
Put some electricity into TBE and Kitty
Who keeps stealing it all? Surely the Jag would be fine?  :-\
Why would it be any better or worse than anything else? Battery technology hasn't changed since your dad was born...
Because it would be used regularly? I've not had to touch the 3.2's battery for least a year and it's only been driven once a week for past 5 months or so. Not sure why you appear to suffer such bad battery loss  :-\
Same reason he can't buy anything off eBay without getting shafted? User error..  ;)
* aaronjb runs off and hides in case Dad gets the slipper out.
;D ;D ;D ;D
Nothing thanks to the useless nucts at DHL >:(
Generally, the Battlebus isn't used ever. The Jag gets irregular use, and the jury's still out if the battery is knackered, and TBE gets used most. Currently, because TBE is broken, much like its owner, the Battlebus is getting loads of use, TBE and the Jag sit unused. Neither were flat, and both would have started without issue, but we all know its retarded to leave a lead acid battery for long periods whilst reasonably discharged, or for even short periods when heavily discharged.
So they were topped up with nPower's finest :)
I'm yet to determine if the Jag keeps accessory sockets live, or if it turns them off after a period of time, then turns them back on when unlocking.  Fair to say, as I keep forgetting to disconnect the gayPod, that always appears to be fully charged :D
jimbo125
It moved it's alive ok it started  that's a bonus
2.5V6 Had it since 2002, what a beast, worth the time and effort to keep it road worthy. Vauxhall bring them back!!! Laser timing kit for OOF member hire
johnnydog
Absolutely nothing, as I'm on holiday. But I thought I'd try to get the first post on page 1000 of this topic... :)
johnnydog
johnnydog
#14979
Quote from: johnnydog on 26 August 2017, 14:03:03
Quote from: johnnydog on 26 August 2017, 14:04:13
Shucks....failed....! >:(
Quote from: Doctor Gollum on 26 August 2017, 15:13:10
Quote from: Doctor Gollum on 26 August 2017, 15:12:29
Have another go :D
Three goes for a pound ;D
Must be worth another punt then..... :y :y :y
Migv6 le Frog Fan
Migv6 le Frog Fan
Borrix. I thought that post would have done it.  ;D
Migv6 le Frog Fan
johnnydog
Quote from: Migv6 on 26 August 2017, 15:53:28
Not worth the bother.  :D
Not much else to do though other than take another sup of my beer, enjoy the clear blue skies, the hot sun and wonderful views across the coastline. Oh, and read what is happening on the OOF.....! Tough really.. 8)
johnnydog
Also spotted a prefacelift 2.0 estate and a facelift 2.2 saloon earlier today. Both base models and left hookers though....
