biggriffin
Quote from: VXL V6 on 16 September 2017, 20:47:30
Went to Huntingdon in one of them  :y
I know, does it stop now. :y nice new wheels n tyres, also could do with some waxoil underneath... :)
Hoof'land storeman.
Rewired a Skoda Octavia drivers door for next door...
Apparently Vagcom cannot solder ::)
Quote from: biggriffin on 16 September 2017, 20:50:32
It'll be going for a couple of days up to Rustbuster's for the full treatment.  :y
Quote from: Doctor Gollum on 16 September 2017, 20:52:31
So VAG door looms haven't got any better then!
Quote from: VXL V6 on 16 September 2017, 20:56:57
Apparently not ;D
tigers_gonads
Replaced the rear donut bushes with polys  :y :y
While the back end was in pieces ......
Attacked the rear chassis / wheel arches with a wire wheel on the drill to get any rust off.
Gave everything a good dose of Krust then blathered everything in black chassis paint  :y
Evened up the handbrake via those little hidden wheels which I can never remember which way to turn  :-[
Gave all the brake pipes a good rub down then sprayed even more white grease on them  ;)
Replaced passenger door latch/locking motor in the Jag. Took pics this time and did a guide for one of the Jag forums...  ...not that they have a section for guides, probably because all Jags come with a little man in the glovebox that "just sorts everything out".
Clearly, my man is missing :D
Quote from: TheBoy on 24 September 2017, 19:44:16
Or he has quit, in protest at your driving  :P  ;D
Send me a link to that guide, might need it one day!
Quote from: tunnie on 24 September 2017, 19:46:27
On the big more UK focused Jag site ;)
Can't be arsed with the more Yankee orientated ones (and struggle with the UK one a lot as well), as standard answer is "take it to dealer".
My experience with Jag dealers is approximately the same as with Vauxhall dealer service departments. IE, shit. Worse than shit.  Clearly this week, whilst it was in there, one of there saleman went out for an extended lunchbreak in it. self-abusers.
I'll probably be looking at XF's in the near future, so worth knowing  :)
Quote from: tunnie on 24 September 2017, 19:52:17
But you wouldn't be so retarded as to take it to a dealer anyway ;)
TD
Quote from: TheBoy on 25 September 2017, 17:10:37
Well......it appears you did  ;D ;D
Quote from: TD on 25 September 2017, 18:39:00
Against my better judgement. But it was a recall that only a dealer can officially do :(
mandula
Replaced headlight level adjustment blocks. Both were broken from body, ball joints were intact. Maybe somebody tightened them too much or something.. Easy job, took maybe 1 hour (never done this before).
Could not contact the guy who advertised aluminium blocks here, so I got these instead.
amba
Make sure you run a tap into the thread to clean up swarf from machining before fitting,as set I used the thread got stripped on first assembly and required dismantling again .
Also worth running a flat file over all edges as unlike the aluminium ones they are not too smooth from the moulding process. :y
