Quote from: Omegatoy on 10 January 2012, 19:26:19
Quote from: TheBoy on 10 January 2012, 18:44:23
Quote from: Omegatoy on 09 January 2012, 20:46:05
as its only me i will allow to work on my car
I've always said you are a rather hooligan :P
lol I remembered!!! must have leant me arm on it when i was tracing the diesel leak down the bottom back of the cylinder head!!  :-[
I repeat, rather hooligan :P ;D
Reminds me, must paint that mangled garage door level ::)
Jacked her polo up to inspect the noise of a buggered back box(  ;D ) and noticed a rattle from the pulleys in the engine bay... again.
Wheel off, liner off, cover off with the most stupid screw on clips, aux belt off, start engine.... Still doing it, 'dangle berries'. New cam belt and water pump needed, re seal sump which means drive shaft off. .... Or chop it in for an Astra J Elite....?
Decision time, this could take a while.
Auto Addict
I like red cars
Omegatoy
Quote from: TheBoy on 10 January 2012, 19:42:40
nah, its only been nearly 5 yearssince it was "adjusted" into a much needed special tool, and its a great
reminder of a how too!!!! ;D
Tonka.
Put a new brake light bulb in. Not at all interesting  ;)
The happiest people don't have the best of everything,
they just make the best of everything they have.
Omega_Dan
Finished off treating the spot of rust under the wheel arch. painted and undersealed. all looking good
SIR Philbutt
Quote from: chrisgixer on 10 January 2012, 20:29:13
FFS, what's dangle berries? ;D
Berries that dangle  ;D ;D
but not neccasarily from a tree or bush and may not be red unless bruised  :y
Webby the Bear
Quote from: Tonka. on 10 January 2012, 22:13:32
I did mine the other day. Piece of Dangleberrys ( ;D) innit  :y
RIP Paul Lovejoy
Auto Addict
I like red cars
Murph
Started work on mine.
Removed upper inlet manifold, replaced the heater bypass valve (suspect cause of DIS failure) and removed the DIS pack.
Replacement DIS arriving in the morning so hopefully tomorrow will see her running.
Swapped all the parts off the old radiator onto the new one and fitted the radiator ....took the aux belt off ready for replacement , no swear box needed today  :) :)
Made a supporting bracket to hold the cooling fans upright as the rubber grommets have gone out of shape , painted all the pulley's which were a shade of rust and now shiney black ...show winning engine bay                "not yet"   ::) :y
pirate
finaly fitted the uprated gas front shocks e-bach springs new mounts she sits low and mean now old shocks completly fobard no wonder she wallowed up front . she goes round corners flat now superb and i can turn of traction and drift the arse out and control it nice. pictures to follow when my new computer and my new camara decide to talk to each other bloody tech drives me nuts 8)
Webby the Bear
Serviced the wife's Focus yesterday. Was real easy!
Spark plugs so accessable compared to mine!  :D
One thing though... i borrowed my mate's socket set and he gave me the socket with the plastic ring in so the s/plug would oull out once unscrewed..... i dont have these. is there simply a plastic fitment that wil slip inside my socket when i wana do plugs? or do i have to buy the socket with the fitment already?
cheers
RIP Paul Lovejoy
