smithpa7
Two new tyres fitted and filled the almost empty fuel tank. Over £300 in one day :(
pirate
more prep before it goes to my mates paint shop tommorow should be all done by weds i hope, then ive got drop links to do upset one on the rear when i did the springs i reckon :y
Changed a valve in Mrs TB's tyre. Not that then :(
Mine, sod all. Again.
Drove it to work,faster than its been driven for a very long time(I really must change those front tyres) ::)..........cleaned the shite out of the interior. Thats it for today. :)
Fixed "her" heated seat, thanks to TB. See other thread.  :y
Flushed the cooling system and added 5 litres of recommended vx antifreeze , fitted new non air/con belt for bypassing the air/con ...hardest part was getting the fekin bagpipes onto the plenum  >:( >:( >:(
geoffr70
Quote from: eatmydust on 22 January 2012, 18:07:09
Yeah that's bloody fiddly that is
TC and BnQ Trade holder.
Quotebloody fiddly
You aint kidding  :D, looks a simple enough job . Nearly ended up splitting the edge of one of them ...vx engine bay designers eh  ::) ::) ::) ::) ::) ::) ::)
Omega_Dan
Quote from: Albs on 22 January 2012, 17:26:48
Are those still the ones you bought off me mate? Cleaned it today as it had 2 weeks of filth on it and the number plates were becoming unreadable ;D
Yes Dan. ::) ;D ;D.............best £45 I ever spent. :y ;D
twiglet
Update from the past week or so...
New wheels shod with some lovely new rubber, and fitted to the car.  I had my doubts as to whether they would suit the car, but I'm very happy with the result!!
Also took delivery of some Irmscher and Steinmetz goodies, which will be making their way onto the car shortly!!
All in all, it's coming along nicely!!  ;D
paul.lovejoy
Quote from: twiglet on 22 January 2012, 22:38:20
any pics coming soon :y :y
paul.lovejoy
maybe i have too and was just saying that in case you felt left out :P :P ;D ;D
Ken T
My wipers have been "challenged " since I bought the car, there was about 3mm play in the motor gearbox bearing, so I fitted a replacement sourced from Rob, works a treat now  :y :y :y I also replaced the rear vac solenoid that got bust during my crank sensor change  :o :o
I had a recent problem with the car "being fragile " and cutting out after 50mins ?. Fault codes suggested Crank Sensor or Cam sensor, well no brainer, its the crank sensor, so I changed that a couple of weeks ago.
Unfortunately that wasn't the solution, and the car has been regularly cutting out on the M62 after 50mins, usually in the roadworks with no hard shoulder  :'( :'( :'(
However further playing with my code reader showed up a cam sensor fault on its own, so I got one and fitted it and the hard starting/running fragile has gone, the acid test is tomorrow morning  :y :y :y
We also cleaned out the breathers and  I checked the plug wells  :'( :'( :'( :'( :'(
And the squeak from the cam belt area at start up, I think I know what is causing that  :'( :'( :'( :'(  :-[ :-[ :-[ :-[  :o :o :o
Ken
