tgm147
Contemplated setting it on fire. The current list of problems are:
1) Severe coolant leak from a stupid pipe under the alternator.
2) Never stops coughing steam out the back, lots of pressure in the water system. Suspecting head gasket.
3) Jerky when crawling again.
4) Sodding drivers airbag quid high resistance error code.
5) The rust is starting to attack the arches but the money I had saved for this is now going on the head gasket.
6) The CD player has finally given up.
7) Getting through 50 litres of LPG in 200 miles at most.
8) Needs a new coolant bottle top - current one sometimes leaks.
9) Still got a knackered shock and spring - waiting for the Koni shocks and Weitec springs to turn up.
Someone show me the light and why Omegas are good again?  :'(
paul.lovejoy
SteveAvfc.
Put the old girl in the garage today for an MOT re-test after failing on Friday, but it,s not bad news as it only failed on a rear coil spring being broke happy days. A big thanks to everyone who has helped me out this past year your advice and guides are worth there weight. :y :y :y
buttsy19
Cleaned all breathers, throttle body, and changed the rocker cover gasket, backed the nut off the drivers electric seat height rod as the bloody thing was jammed in the up position, and hoovered it.
Sorry but it had to be done.
If it aint broke, break it, then fix it
Corrado1441
Refitted rear passenger door panel after reglueing plastic trim that holds panel along top edge of door, also painted wooden insert gloss black.
Now have to do the same on other rear door  :)
Stallion
took both rear doors off, put newly bought doors on 20mins, rewiring, cutting speaker hole, feeding wire through 2hrs  :( was worth it :y
andyc
Thetford. Norfolk
Quote from: andyc on 31 January 2012, 09:24:30
Quote from: TheBoy on 30 January 2012, 18:23:16
Quote from: andyc on 30 January 2012, 08:53:36
Thats my place in the picture
Andy
Oh, you git  >:(
;D ;D ;D
Better not show you the full size of the shop then :y
Not unless you want us all piling round for a "cam belt meet". ;D
andyc
Might be a bit tight as there are nine cars it there at the moment, most of which are in various states of dis-repair
Andy
Thetford. Norfolk
pirate
done the front and rear anti roll bar drop links .and the back ones are a bastard had to cut them off in the end but worth it no slight knock from the rear now, bottom of three doors painted nice got a tiny bit of rust to do in inside edge of n/s rear arch paint shop forgot that bit so going back soon, then the wrap to go.
saw the link to supercharger bit home made but hay if it works im waiting for parts from germany proper steinmetz parts :y
Omega_Dan
Changed the oil on the van today. Absolute Doddle to do.
SteveAvfc.
Car back in today for MOT retest and for once good news the rear broken coil spring was not broke after all, garage said once they removed the wheel closer inspection revealed it was OK its rough at the top and that's why they thought it broke. So what that means is she pissed it yahooooo  :y :y :y :y :y :y :y
Quote from: andyc on 31 January 2012, 12:59:18
Andy
Good recovery.   ;)   ;D
