Did a bit of maintenance today. Lifted the bonnet and pulled the dipstick out. There was black, slippy stuff on the end of it. Put it back and closed the bonnet. That was enough maintenance for one day.
dave the builder
Quote from: STEMO on 13 April 2019, 20:38:38
did you wet it all down with a hose pipe  :-\
Quote from: dave the builder on 13 April 2019, 20:43:38
Come on, I was knackered after that little lot.
dave the builder
Quote from: STEMO on 13 April 2019, 20:46:37
??? who's doing fire watching then  :-\ Mrs Stemo  :-\
Quote from: dave the builder on 13 April 2019, 21:00:49
I have moved her car so as to leave a couple of the neighbours in a more vulnerable position.  ;D
dave the builder
Quote from: STEMO on 13 April 2019, 21:13:52
Good man  8)
Keith ABS
 Tucked the V8 up into the garage by bringing the Monza out
To unwell to go to the autojumble at Bovingdon today so will do the cafe meet and then a drive in the Monza to wake up a few people
Viral_Jim
Changed the front pads on the terracan, also bought timing, aux and power steering pump belts, it's early on the project list once I have a garage to do it in.  :y
Quote from: VXL V6 on 13 April 2019, 19:05:37
Quote from: TheBoy on 13 April 2019, 18:12:51
Quote from: VXL V6 on 13 April 2019, 16:25:28
It's the age old problem, what do you replace them with if you want something that has all the good attributes of a V6 Omega but about 5 - 8 years old and under £8K.
Low spec 2011 XFs are starting to fall into that bracket, but in your case, check the boot size. Trouble with other rwd marques from that era, base spec means poverty.
Yes looked at a couple of XF's, no good for me as boot is far to small and access to it is too narrow, plus I wasn't overly convinced by the handling (that said the vehicles I tested were 5 years old so not the freshest of suspension).
Low spec... No thanks.
Low spec is relative. They are all well specced, even the bottom end Luxury.  But irrelevant, if the boot is too small :).  I think you are in for a struggle to get a saloon with a boot as big and accessible as an Omega.
Quote from: TheBoy on 14 April 2019, 17:25:44
Forget how large the XF boot is.
The car is essentially a 2+2 unless the driver and front seat passenger happen to be a dwarf or midget.
I can fit in the back comfortably enough....
Yes X250 is not to bad, the X260 being much much better but no V8 option
Had a random flip round Autotrader, seeing if there is anything to replace TBE with.  Unsurprisingly, it wasn't a fruitful exercise.
dave the builder
spent a few days looking at all the car trader sites to find a  zafira B  to replace the last corsa on the fleet,  7 seats needed apparently  :-\ corsa has a boot that you could cram at least one body into  ::)
seen some right heaps , why do people lie when they advertise cars  >:(
drove many miles to see junk ,only fit for scrapping
then , get sent a link for one local by my brother , about 20 houses down the street .
(so close, i walked   :o :D)
mint car,lovely people, 12 months mot ,deal done , :)
collect tomorrow , will need to do the cambelt (i think Terry has a guide  ;D) etc and check it over,rustproof etc before it joins the fleet (even though it has a new MOT) because it's family  ::)
Quote from: dave the builder on 21 April 2019, 18:34:33
Do you ever have time to do any actual building, or do you have minions for that?
