dave the builder
Quote from: aaronjb on 25 April 2019, 13:55:09
Quote from: dave the builder on 25 April 2019, 13:34:41
wonder how my omega will feel about that  :-X
Watch it doesn't run over your toes for you.. or any buckets.
since the "bucket incident" I've installed BARCS  bucket avoidance rear camera  system   :y ;D
Quote from: Sir Tigger QC on 25 April 2019, 14:00:03
It'll probably spit it's dummy HBV out!  ;D
I need to refresh the coolant anyway  :P
biggriffin
Phoned up to change the insurance from the barge to the slap,,, That'll be £30.. please sir, £25 change over(admin cost) and £5 increase.  :o
Hoof'land storeman.
Keith ABS
Quote from: tunnie on 24 April 2019, 22:11:40
Quote from: TheBoy on 24 April 2019, 19:34:52
Got a LPG burn whilst filling up.
That's gonna smart in the morning :(
Reliability of LPG pumps were shocking, couple I used the filler would get super cold. Had to be quick in releasing.
Probably more likely your filler TBH.
My burn was from the gas escape upon removal.
Quote from: Migv6 on 25 April 2019, 11:07:10
I got burnt by an LPG pump a few years ago. It stung quite a lot for several days.
But as you know TB, a bit of pain never hurt anyone.  ;)
I couldn't agree more. Whats a bit of pain, it never harmed anyone.
I was right though, it has smarted all day.
Migv6 le Frog Fan
And will keep smarting for around a week ime.  ;)
Quote from: TheBoy on 25 April 2019, 18:10:16
Filling was fine at other pumps, just one pump was temperamental
Quote from: tunnie on 26 April 2019, 11:18:26
If the pump nozzle was freezing, its most likely due to a restriction around that area.  I'd expect that if it was the pump, and same for everyone, it would get looked at TBH.
So may be a combo of that pump nozzle being borderline and your filler being borederline, and the result was that. If that makes sense.
The sort of burn you get from touching a frozen nozzle is nowhere near as bad as getting caught by a gas escape when removing.  Hence I've been all gay, and been using aloe vera on my poor index finger.
Tried and failed to drive it earlier.  I feel like a Viagra has got stuck in my neck.  I couldn't even look right at the first roundabout, so I swung round it and straight back home.
YZ250
Quote from: TheBoy on 26 April 2019, 19:19:44
Minor detail, just pull straight out, everyone around here does so it must be ok.  ::)
Quote from: TheBoy on 26 April 2019, 17:45:15
What are you, man or mouse?
I can hear the squeaking from here :D
Quote from: tunnie on 26 April 2019, 20:54:29
A couple of weeks ago, I got, ironically the same finger stuck on the hotend of a 3D printer at ABS temps (240C).  As you can imagine, that made me yelp.
But I reckon a gas burn is every bit as bad.
Broke the V70.  :(
The button on the gear knob broke and fell out, and I can only use D and N.  ::)
It happened just as I was about to set off for Dorset from South Wales and I was in a cul de sac facing the wrong way!  ::)  I managed to turn around by going up on the pavements, which was lucky as the V70 has a crap turning circle.  Once I was pointed in the right direction, I didn't stop until I got home!  ;D
Viral_Jim
As a temporary fix, if you pop the trim pieces off around the selector you can manually move the linkage (same way as pressing the button) I think.
Its unlikely to be wasted effort as the trim comes off to replace the shifter anyway.  :y
