jonny2112
Quote from: JamesV6CDX on 12 February 2012, 01:33:18
Changed a 3.0 V6 Thermostat and full service in Surrey. Brrrrrrrrrrrr!!!
Glad you got sorted though  :y did all go to plan?
Omegatoy
Gah!! had to change a set of glowplugs on a vw 2.5tdi 5 cylinder yesterday, pain in the arse job!!! :-[
Rebooted the arse end of the Silver Bullet yesterday, and got the geometry tweaked. Geometry wasn't too bad, despite the poly bush fitting a few months ago. Oddly, rear toe had drifted, not quite sure how. At the front, NSF camber had altered - whether polys did that, or one of the various launches its had over the past year...   ...not to mention, as those who have been to my gaff, all those vicious speed bumps.
On the way back, I decided to have myself some fun aroud the lanes. Despite the low temps, the roads were again spookily dry, and the wet/icy parts easily visible. An odd sensation whacking through the lanes with snow everywhere. Although after 20 mins, I started getting neck ache, so went back to Miss Daisy mode.
joff
Put a new MoT on the 3.2 elite Friday small hickup with a rubber ball joint dust cover but all done for another year :y. Now need to do the brothers elite estate dti for an MoT soon, not very nice working on cars outside when it's Brrrrrrrrrrrrrr -8 :-\
Couple of fuel drains yesterday on other peoples cars but bloody cold!
Neighbour needs the rear pads changing on his Avensis but not sure I fancy being outside today ::)
Went to the shop round the corner "wont be long"  :-X
Took me half an hour as decided to blow some long overdue cobwebs out ...... :P
Must change the front tyres .
Checked all fluid levels "spot on" .
Need to do some bodywork but far too cold .
Quote from: TheBoy on 12 February 2012, 09:54:37
Have you seen the quack yet?
Quote from: chrisgixer on 12 February 2012, 12:42:59
I think we both know the answer to that ::)
TB, you need to get to the quack... I know you dislike them but you must get checked out. You obviously have some underlying issues that need sorting or you will have serious problems for life ;)
There is talk that my back issues are all related to an accident I had back in the '90's
joff
Just topped up the Elite as i had 10p off a ltr so put 47.28ltrs of momentum99 in that took it down to £1.28ltr. then went home to see why the Astra H heater was not pushing out hot air, only to find out there was no coolent in the header tank(only checked it the other day) so topped up with 50/50 mix, took it out for a run and i can't find the leak anywhere ??? :-\ that will be another cold job this week :'(
Somehow I suspect the only thing that'd make TB go to the quack is if his head dropped clean off his neck!
bored bigyin54
just given the car a wash  get the salt off
Edit
Swore at it !!!!!  Coolant light on again after all i done  >:(
PAULCDX
I've had the theromostat changed on my V6 today, by JamesV6CDX....... I've now got heating that works lol.....  ;D
Nice one James !  :y
Omega_Dan
General lights and levels check and a good wash as it was covered in crap from the recent weather. Lowered suspension had a good workout today as me and 4 Mates went out in it. There all about 13 to 14 stone and im 16 ;D
Went to get something out of it and discovered the battery was flat >:( Not really surprising... I don't think it's moved for 6 weeks and certainly hasn't been started for over a month ::)
Guess I'll have to get some petrol into it so I can start it and charge the battery ;D
Stripped down the rear brakes on the neighbours Avensis to find that he'd been given the wrong pads too ::)
Oh... And another couple of drains for other people :y
