Quote from: Doctor Gollum on 12 February 2021, 19:27:57
Heated jets are easy enough to retro fit. The Barge has the potential to heat the washer bottle, which whilst not fitted, is a couple of hoses that run from the hbv to the bottle and back, so would be easy to retrofit. The jets are heated though 8)
Guess that Jaaag chose to save 50p by not cutting a couple of notches above the front doors for the retaining clips for the grab handles and another 50p not fitting the handles...
Does the XF have handles that might be retrofitted to the XJ?
Heating the bottle isn't going to help if the pipes and (in particular) the nozzles aren't heated.  The bottle isn't subject to much windchill, which is why cars have heated nozzles.  I am of course making an assumption mine hasn't got them, but the fact they froze.  Its is of course possible it has them, but they are bust.  If I CBA, I'll go out and look for any wiring to the wiper arms :)
No idea on the lack of a passenger grab handle.  Rear passengers get them, just not the front.  Does seem a significant oversight, even if its for technical reasons (the shape there, along with the sunroof cassette, doesn't look conducive to fitting any).  No interest in retrofitting any unless it was a pure plug and play operation, mostly because its not often I'm in the passenger seat at a time when I feel I need a grab handle.  And for anyone else in the passenger seat, well, they chose to get in.
Vauxhall obviously went the all in route, some use a sunglasses holder for the driver... having the wheel to hang on to helps :D, so retro fitting a handle should be plug and play.
Guessing your roof is panoramic, which would certainly push the frames to the side structure...  :-\
Quote from: TheBoy on 13 February 2021, 12:35:54
Mine hasn't got them either, and they tend to freeze. Can still hear the motor running so clearly the bottle hasn't frozen solid.
Mine has also started pestering me that the bottle is empty when it isn't.  >:(
Migv6 le Frog Fan
Took delivery of the Porsche.  :)
Wont be long before I feel the wind in my scalp.  :D
dave the builder
Quote from: Migv6 le Frog Fan on 13 February 2021, 13:45:35
wait till it's less windy before you go out and start fixing it then  :D
Wont be long before I feel the wind in my scalp.   exit the road backwards scattering expensive(before they were broken) pieces of aluminium everywhere.
FTFY :y
Oooh.....what you got, Mr Bitz. We'll need pictures.
Are you aware that Porsche is a German company, and not French. ::) ::) ::)
dave the builder
Quote from: Field Marshal Dr. Opti on 13 February 2021, 15:01:11
I think he plans to stick the 60MPG , 20 HP engine and drivetrain out of CL-Eeyore , his French tractor  :-\   :D
Check the Project Anyone? thread.  ;)
Migv6 le Frog Fan
Just for you. Pic 9 is a video btw.
https://photos.google.com/share/AF1QipNkrfO-1-yVbB6hqrEqAJZ8M9mc6ECn0bMDuinR-uC9pp0tKgdDcHshLJeuFsZZ0A?key=R3owdkRQbC1aenFhTEFzekszNjJXSWVwaXZyY213
Quote from: Kevin Wood on 13 February 2021, 13:16:53
Yup, I could hear the pump. Plus the headlight washer still worked. So assumed the extra -12C windchill on the wiper arms was causing the nozzles to freeze.
If yours is anything like mine (just aft of front wheel), the sensor is easy to get at once jacked up and wheel off.  The wheelarch liner comes off in no time.  I can grab the official procedure off topix on Monday if required.
I feel some long Porsche threads, detailing every saga coming on ;D
Quote from: TheBoy on 14 February 2021, 10:45:36
We might need a bigger internet for that :o
Quote from: Nick W on 14 February 2021, 11:20:21
I shall get some extra capacity in, just for Alb's Beetle threads :P
ronnyd
Jump started my neighbours shitty, filthy, uncared for, unmaintained 06 Fiesta this morning. Suggested he get the battery checked out as it's the third time this week he's had to have it done. ::)
