Author Topic: So what have you done to your car today?  (Read 6913769 times)
0 Members and 17 Guests are viewing this topic.
« Reply #22785 on: 01 October 2021, 10:45:17 »
I was in my garage, due to needing to check the tread depth on the BBP, and also to reset the service indicator.
I got as far as booting the PC, but was overcome with CBA rain stopped play.
Service interval rest yesterday.  Missing electricity follow said process being returned to it as we speak.
Rear tyres are a touch under 4mm across the width of both.
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #22786 on: 01 October 2021, 11:24:08 »
As you know, they recommend connecting the charger when you do this to maintain voltage stability, but we think it won't take long so we'll risk it.  ;D  Had to plug mine in to VCDS the other day, as I carelessly leaned on the start button with the MMI disconnected, throwing airbag codes.  ::)  The Nav aerial needed replacing so I leaned across the centre console to unplug the harness and heard the booting up noise. When I'd sorted the aerial I had to run a scan and delete the fault code to turn the airbag light off.
« Reply #22787 on: 01 October 2021, 18:02:01 »
I normally put on a set of jump leads to a running car when using SDD ;D
    • 530D M Sport, 330i Coupe
« Reply #22788 on: 01 October 2021, 18:26:05 »
Had the Camcover gaskets done by SOS yesterday :y and did an oil and filter change today.
Keith ABS
  • Maldon Essex
« Reply #22789 on: 01 October 2021, 19:27:07 »
 Not today but for tommorrow, going to attempt to get fuel for the Monaro for a show at Thorsy Park on Sunday week. Last one of the season I think
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #22790 on: 01 October 2021, 19:49:18 »
Keith I know that Tescos Maldon had fuel a few days ago. No-one in Witham did.
Yesterday I went to Sainsburys Tollgate, drove straight in without queuing and filled up, so if nothing doing in your neck of the woods.....
Keith ABS
  • Maldon Essex
« Reply #22791 on: 02 October 2021, 07:17:35 »
Thanks mate. I visited 12 places Monday night to get fuel for the bus, with only one having unleaded only. Got some in Colchester on Tuesday morning but they dont do super there
Migv6 le Frog Fan
« Reply #22792 on: 02 October 2021, 08:21:05 »
Went in Morisons in Witham at 7am this morning in Pierre and filed up without having to queue.
As the engine was hot the fickin thing didnt want to start again though. Almost flattened the battery before it fired up.
French crap.  :(
« Reply #22793 on: 02 October 2021, 13:22:09 »
French crap.  :(
Well seeing as you've just quadrupled the value of the thing with a full tank of fuel, maybe now's the time to sell it!  :y
« Reply #22794 on: 02 October 2021, 15:30:28 »
French crap.  :(
Nah.....he loves it too much for that. He loves all things froggie. :)
« Reply #22795 on: 02 October 2021, 16:05:22 »
French crap.  :(
The boggeyed convertible Beetle does bear more than a passing resemblance to a squished frog...  :D
    • E250 Est / Elroq
« Reply #22796 on: 06 October 2021, 21:01:47 »
Mot'd the Merc, nice clean pass
Moved insurance, saving £100 on last years price, and 75 off renewal.
down to £205 for a year.
« Reply #22797 on: 08 October 2021, 18:20:47 »
New thermostat on the Mondeo and now the temp gauge behaves normally.  :y
Strange thing though.... it's got much the same engine as the Jaguar XF and LR Freelander, so the same thermostat fits all three.  However the thermostat for the XF and Freelander was £6 cheaper than the Mondeo.  :-\  So I treated it to the Jag stat!  :)
Meanwhile it's developed a nice whooshing noise when accelerating and sure enough I found a hole in the turbo boost pipe, so one on order.  Only a tenner so not that bad.  :y
« Reply #22798 on: 08 October 2021, 18:36:03 »
Is that the same lump as the Volvo D4 circa 2010 :-\
If so, how do you find it?
« Reply #22799 on: 08 October 2021, 19:34:13 »
You pull the little lever in the passenger side footwell, then grope around under the bonnet lip for the catch and when you find and release it, lift the bonnet up and Ta Dah!   There it is!  :y                                       :D  ;D
