Quote from: STEMO on 10 March 2022, 14:10:19
Quote from: Field Marshal Dr. Opti on 10 March 2022, 13:19:25
Quote from: STEMO on 10 March 2022, 11:06:09
Car was a bit sluggish turning over this morning. Once started, the indicator relay was slow and the air con display had some elements missing. Battery, I thought. Got to the woods with dog at about nine, rang my go to chappie who said 'I'll order one, half ten okay?'. Down to garage at 10:30, battery fitted and home now. £107, no dramas, just as it should be.  :y
Are you sure the battery is donald ducked?
In another life I owned a Datsun with a battery that kept going flat. New battery didn't cure it, and it turned out to be a faulty voltage regulator.
Was it the original battery?
No, I've made a terrible mistake  :(
What would we do without you and Al?   ;D
Sarky old bugger. :)
Flat battery can be down to more than just the battery going flat.
You didn't say how old the battery was. :)
Quote from: Field Marshal Dr. Opti on 10 March 2022, 14:25:52
I didn't need to, everything is in order. Thank you for your concern  :-*
Diesel till I die
Quote from: STEMO on 10 March 2022, 14:29:08
No problem, old lad. :-*
When your new battery goes flat within a week you can buy a new one. that'll solve the problem for another week. ;D
Quote from: Field Marshal Dr. Opti on 10 March 2022, 14:36:11
If you say so, Mr Motor Engineer  ;D
Diesel till I die
dave the builder
MOT station re-opened so I dropped the Zafira A tractor juice edition in for a test .
passed with no advisories (I'd checked it all over first anyway )
I was glad to get back in my Omega after  :P
Rangie
#23495
Quote from: STEMO on 10 March 2022, 14:48:23
Oh dear hope I didn't make a mistake replacing mine in the Range Rover 18 months ago, such good & caring advice on here 😂😂
Changed 3 glow plugs on the Battlebus, then treated it to an oil change.
After that, gave it a damn sound thrashing to test it.  Most enjoyable.
Notice there is a lot of people broken down over the past few days, wonder why that is?
Quote from: TheBoy on 10 March 2022, 19:39:35
Can't be the same glow plugs as my astra, then, or you'd have been £360 lighter.
Diesel till I die
dave the builder
Quote from: STEMO on 10 March 2022, 19:56:20
the genuine Bosch ones are less than £10 each for the Zafira A  :)
Quote from: dave the builder on 10 March 2022, 20:19:03
That's nice, bastid  ;D
Diesel till I die
dave the builder
Quote from: STEMO on 10 March 2022, 20:28:48
I've got lots of dads  :D
They've run out of fuel because they can't afford to fill up anymore?  ???  :D
Migv6 le Frog Fan
Took the newly rebuilt and now insured french contraption for a drive this morning and all was well.
Drove it to work this evening and engine bay as dry as a bone when I got here, so it looks like its back to full working order - for the moment.  ::)
Shall fill it with diesel tomorrow and keep my fingers crossed.  :)
dave the builder
Quote from: Migv6 le Frog Fan on 10 March 2022, 21:03:58
Well done  :)
You'll double it's value with a tank of diesel though  :o
Well done, Albs, I admire your perseverance  :y
Diesel till I die
