Migv6 le Frog Fan
Did some dismantling of Pierre again,and may have found why the new camseal didnt seal.
Radial scores around the nose of the cam, just where the seal sits. Dont know how its happened, but would imagine it wont do the seal any good.
I have a new genuine Renault seal here, but might need to get a new cam before I think about using it ? :(
Viral_Jim
Are they too deep to take out with some emery paper?
Migv6 le Frog Fan
Hard to tell without trying it and then putting it all back together and see what happens.
Trying to avoid that as this is the fourth time Ive had it apart and am seriously sick of it now.
Thinking of trying an SKF Speedi Sleeve if I can find one of suitable dimensions.
If you can feel the damage with a finger nail, then it requires machining/replacing depending on the clearances ;)
Migv6 le Frog Fan
Yep I can feel it with my fingernail. Decided to give the Speedi sleeve a go. They look very impressive.
Quote from: Migv6 le Frog Fan on 25 February 2022, 18:37:38
What's that? Like a condom for a camshaft?
Diesel till I die
Just had a look, seems like the easy option and, if it didn't work, I'll bet you can strip it back down in under ten minutes now. ;D
Diesel till I die
Migv6 le Frog Fan
Not quite, but its a lot quicker than it was the first time.  ::) ;D
Migv6 le Frog Fan
Viral_Jim
These look like an excellent bit of kit, but whats to stop leakage between the inner face of the sleeve and the original shaft?  :o
Migv6 le Frog Fan
A very tight interference fit. They are designed to be used on damaged shafts without the need for major repairs / machining / then having to use different sized seals etc.
Available up to  very large sizes for industrial use. Very simple looking, but quite clever engineering by the look of them.
GastronomicKleptomaniac
Got a load more bits painted. Also cut out the steering box panel that I tacked in yesterday because I wasn't happy with it... A lot more use of the Birmingham spanner has got the new panel sitting much better ..
addy
The way you are getting on with welding GastronomicKleptomaniac. I will be surplus to requirements. ;D
Drives 1995 2.0ltr CD Estate.  2002 2.6 CD saloon
Quote from: addy on 27 February 2022, 15:54:47
Leaves more time to drink coffee and talk 'dangle berries' :y
