Author Topic: So what have you done to your car today?  (Read 6913716 times)
0 Members and 15 Guests are viewing this topic.
« Reply #23385 on: 11 February 2022, 15:49:07 »
Sold The Barge.
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #23386 on: 11 February 2022, 17:56:31 »
Loaded it up & taken more " antiques" to the auction rooms.
kwhite@fsmail.net
  • York
    • 2002 2.6 CDX
« Reply #23387 on: 16 February 2022, 14:25:03 »
Just changed the auxillary belt tensioner pulley.
So nice when a 2 minute job actually only takes 2 minutes.
Now have both stopped whining.
« Reply #23388 on: 16 February 2022, 15:31:50 »
Got an MOT on the Battlesbus a couple of weeks ago.
Its going to need a new exhaust, but struggling to find one believe it or not.  Euroshite have a Klarius one for around £150...  ...but seeing as the backbox is a 2 year old Klarius from euroshite and already shagged......
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #23389 on: 16 February 2022, 15:32:03 »
Stopped whining Mm🤔..  do wives have belts? ;D
Laying a rubber road.
« Reply #23390 on: 16 February 2022, 16:05:16 »
At least it should unbolt easily...
Have you tried Peugeot?
Or if you plan on keeping it until it becomes MoT and tax exempt, then you may as well get a custom stainless one made...
« Last Edit: 16 February 2022, 16:07:52 by Doctor Gollum »
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #23391 on: 16 February 2022, 16:46:08 »
Ok, what am I missing?...
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #23392 on: 16 February 2022, 17:45:26 »
Peugeot own Vauxhall, unfortunately.
« Reply #23393 on: 17 February 2022, 15:37:20 »
The flanges holding the bolts no longer exist on the 2 year old backbox, so the bolts dont even need undoing ;D
Vauxgeot can supply one for £300 and something, but will have to wait for it from the fatherland.  I wasn't really planning on trippling its value if I'm honest.
If only the bloody thing would fail, I'd be shot like a, err, shot ;D.  Its horrifically robust, much to a colleague's amusement, following racing steadily driving behind him from a shithole in Surrey to Northamptonshire, and it badly overheated due to a piece of debris blocked the rad.  Debris removed at Beaconsfield services, allowed 20mins to cool, then we set off again like a bat out of hell.
« Reply #23394 on: 17 February 2022, 15:58:53 »
I got £1,900 for the Barge... You may want to reconsider its value...
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #23395 on: 17 February 2022, 16:25:58 »
After some creative welding and a few choice words, finally got the last locking wheelnut out.
Then did a bit of therapeutic arson, burning the old suspension bushes out. A good day.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #23396 on: 17 February 2022, 21:17:47 »
just cut off the remainder of both flanges and fit a repair sleave or flexi joint
should be good for another 100k
I replaced the mid box on our tractor with a genuine GM new old stock one I had (I purchased many zorst parts when GM got sold)
only the rear flange had rotted .
save yourself the hassle and do a repair  ;)
« Reply #23397 on: 18 February 2022, 10:17:23 »
thats not a bad idea, Mr DtB :y
I'll have another look under to see if thats viable/worthwhile, but not until the wind drops a bit.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #23398 on: 18 February 2022, 10:31:06 »
the back box might ,but my advice above about cutting out the flange and fitting a repair sleeve is based on me replacing the mid section on the same model Zafira A 2.0 DTi Elegance .
the mid section has about 6 or 8 hangers and after 20 years the front and mid section had welded themselves together and i had to cut the mid section off the front section  which is right under the car and awkward.
the rear flanges mid to back box are easy to get at with the spare tyre removed so repair is easy .
a clamp on repair sleeve can be had for sub £20 delivered ,will do the job and save hassle and £££
Sorry but I can't do anything about the "wind" TB  ,I had a curry yesterday  :D
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #23399 on: 18 February 2022, 11:07:37 »
IF the mid section is beyond a simple sleve fix ...
GM236T £40 in Loughborough clicky
Regal mid and back box £98 delivered clicky
Mid section £42 delivered clicky
but a sleeve repair (if possible ) would be easier  :)
cross reference Part Numbers: GM346
Product Description: ZAFIRA 2.0TD '99-02 SCP
OE : 24436127
Klarius: GM346T
Bosal : 284-633
Euroflu : EXGM3062
Walker: 71678
RENAU : 8671015187
VAUXH : 5852132
VAUXH : 24436127
VAUXH : 90581544
EBERS : 08.200.80
WALKER : 71678
WALKER : 72378
WALKER : 66-71678
WALKER : 66-72378
ERNST : 042 08 6
BOSAL : 284-633
ANSA : OP27005
FENNO : P4511
FONOS : 617678
IMASAF : 54.87.26
ROSI : 42363
MTS : 01.59430
RHIAG : 43245
RHIAG : CT 43245
VENEPORTE : OP40455
KLARIUS : 260770
KLARIUS : GM419K
FABRISCAPE : OP33413
STEC : KLR260770
EUROFLO : EXGM3062
