Rears on the BMW are £650 a pair and fronts are £445. Ask me how I know LOL.
Put the Monsit through an 'up and over' car wash while I munched an ALDI egg and bacon sarnie.  >:D
BazaJT
Took V70 for M.o.T. it failed :'( Fortunately it was only on a broken rear spring so as soon as the new ones arrive [although only one is broken I'm replacing both as it's stupid not to]it'll be a case of getting out and under to fit those.
Should be as simple as undoing the shock and a bit of heaving ;)
BazaJT
Yes to undoing the damper from the  trailing arm,however there is a nut under the trailing arm which holds the lower spring mounting and the "bolt" that this screws onto has a tendency to spin when undoing the nut Volvo in their wisdom gave this "bolt" a round flat head [rather like a rivet]making it hard to get a decent grip on especially as it's in the centre of the spring coils.
Raeturbo
Give it a damn good spaying before you start, let it soak a bit patience is concentrated strength👍
Laying a rubber road.
Rangie
Noticed that the headlights ( plastic covered area) on the RRS were starting to show their age & getting cloudy, I had some plastic/acrylic restorer in the garage that I use on the caravan windows so gave it a go & a fantastic result lights look like new again.
Quote from: Rangie on 27 August 2023, 14:38:26
Cheap fix  :y
Diesel till I die
countrywoman
Not a lot, spent the day cleaning/sorting out the unit. Part 2 tomorrow ::)
Rangie
Not mine hers, given the old faithful Subaru a thorough cleaning & polish & it's gleaming ideal day for it today 👍
BazaJT
Fitted new rear springs on V70 yesterday and a retest pass today :y
Raeturbo
Front wheel bearing to my master van🤬🤬😢😢😢
Rangie
Unlocked it & got my sunglasses out, too damn hot to drive anywhere so bit more meat on the BBQ &  a few more cans it's absolutely glorious here in Norfolk.☀️☀️☀️
Migv6 le Frog Fan
Just watch that you dont grow some extra fingers or toes while your there.  :D
Quote from: Rangie on 08 September 2023, 14:44:34
I want to go for a drive. With A/C on full blast ;D
