The Alabama Mumsybus threw a generic glow plug controller code along with the occasional code for a specific glow plug, usually #2 or #4, but never together, although this varied enough to be deemed inconsistent.
Symptoms were long cranking and unburned fuel in the exhaust during cold starting unless the glow plugs were cycled twice. A new glowplug controller eliminated the codes and the cold starting issue.
Point being, it might not be a glowplug fault. ;)
Point being that if a glow plug is open circuit when measuring from the control unit, it aint the control unit, but either the glow plug itself or the loom.  Loom less likely on a sub 20yr old car.
Whether or not that resolves the particular issue of slight erratic idle when starting from cold will not be known until its been replaced, but its a likely candidate and most certainly needs to be fixed before going any further.
Quote from: Raeturbo on 23 September 2023, 20:57:50
Mm ok I thought switch them on from cold for a bit and check each one💁🏿‍♂️
Will struggle for access to do that, even with a IR stat.  If access was easier, I would pop the connectors off the top of plugs, and measure back, but would need a tunnie to get in there without some level of disassembly.  And you can never find a tunnie when you need one ;D
Quote from: TheBoy on 24 September 2023, 12:00:09
I believe Tunnie's are NLA 🙁
Diesel till I die
dave the builder
Quote from: TheBoy on 24 September 2023, 11:57:18
And new glow plug ordered.
you've got form
Try NOT to snap the old ones this time  :P
Quote from: TheBoy on 24 September 2023, 11:56:22
True enough that's after the control unit :y
Quote from: dave the builder on 24 September 2023, 12:57:52
you've got form
He'll have endure the inevitable fiasco of the wrong part turning up/delivery to the wrong address/taking ages because it was routed via Tipperary and Timbuktu first!  ;D
Migv6 le Frog Fan
Finished refurbing the "new" set of wheels for the Boxster. Got 3 hours before going back to work, so could fit them, but suffering a mild case of cba.
And then you'll spen the night looking out of the window thinking 'I wish I had swapped the wheels over :D
Have a cuppa and get it done already :y
ronnyd
Washed it, then attempted to buff out some supermarket scratches and dings. Moderately successful. Did the headlights with some PlastXr too. Do them every month or so to keep them clear so i can see where i'm going.  ;)
you've got form
Yeah, that's scaring me.  Plus the new glow plug needs coding in somehow, and SDD is a right royal pain to use.
Quote from: Sir Tigger KC on 24 September 2023, 14:18:02
you've got form
It was from the Gay or E, so you could be right.  However, I have used this seller before, and they didn't have to go to hospital, or dog died, or granny was ill, or the usual shit from scumbag lazy eBay sellers.
Raeturbo
Quote from: TheBoy on 24 September 2023, 18:34:05
you've got form
Give them a good dose of penetrating fluid now before they come
Laying a rubber road.
Gave it a blast up to Gaydon, then changed the oil when I got back.
Filled up Mrs TB's pigs piss tank.
