Migv6 le Frog Fan
Fixed the indicator stalk and phantom horn on the Boxster. for the cost of 4 O rings and a glue stick in a glue gun.
Both very common problems that cost hundreds to fix if buying new parts.
Indicator stalk is a very fiddly job, involving keeping several little springs and other little parts, in place while trying to get everything back where it goes, but satisfying to complete it for three fifths of far call.  :)
Keith ABS
Pictures are essential! :)
[/quote]
Being very PC illiterate, if I knew how to get pics up on here, I would
johnnydog
Yes, why isn't it straightforward to load pictures on here to the uneducated? The other car forums I visit, it's so easy, and even I can do it....
dave the builder
You need to upload pics to a "host" site ,then copy the url into a post  ;)
I imagine if photos where uploaded to the OOF (and stored on the OOF server)
it would take up loads of space and bandwidth ,slow down the OOF
as Jamie very kindly doesn't charge anyone to view the wealth of Omega information on OOF
it's a small price NOT to pay  :P
though I would gladly pay a subscription , as would many , but that's a "can of worms" apparently
johnnydog
It's that easy....? We shall see... and thanks anyway :y
Migv6 le Frog Fan
Im crap at computer stuff. I use Postimage for hosting as its free and I find it pretty easy to use.
Quote from: dave the builder on 21 September 2023, 21:51:04
^^^ Wot 'e says ^^^
Had a brief play with Mrs TB's little pussy this morning  ::).
Measured all the glow plugs from the glow plug module, to find one is open circuit.  Need to look at a wiring diagram to see which one it is (at £42 a pop, retail, it's only gonna get 1).  Hopefully this is the cause of a slight miss at idle first thing in the morning since the weather has cooled...
Raeturbo
Haven't you got a temperature measuring tool?
Laying a rubber road.
Quote from: Raeturbo on 23 September 2023, 18:28:21
Wiring schems will be easier :)
Raeturbo
Mm ok I thought switch them on from cold for a bit and check each one💁🏿‍♂️
Raeturbo
Probably, but not isolating which one I would think
