Raeturbo
Onboard Britannia, luggage hasn't arrived yet😱
Laying a rubber road.
YZ250
Quote from: Raeturbo on 30 May 2025, 16:21:17
Cruising to the Norwegian Fjords?  :)
Put a new air filter in the Mondeo. The old one was minging so the old girl can breath a bit easier now.  :)
Also while I was in there, I squirted some WD40 into the end of the gear lever linkage cable at the gearbox and think it's not as stiff as it was.  :y
Discovered the worse autobot ever fitted to a car* in the last 30 years...
*does French shit count as a car?  I know it does for Uncle Albs, and his love of all things Pierre.
polilara
Added oil to my Y26SE, it is not leaking anymore, I hope, as garage floor is now dry but stem seals are original. It is really smoking blue in the morning. I undertsood that those seals could be changed without removing heads. Air pressure from plug hole or what?
Migv6 le Frog Fan
Quote from: TheBoy on 31 May 2025, 18:19:46
Never did like you.  :P ;D
Migv6 le Frog Fan
Plan for today was to fit new handbrake cables, a new rear caliper and pads to sons 05 Civic.
After four hours I just about got the cables fitted.
Bastid of a job made much worse by all the mud crustiness and general corrosion on everything on the underside.
Bits of rust flaking off and falling in my eyes, corroded nuts ,and one captive nut making its escape........
Had a prod of one really bad looking part of a sill and ended up with a fist sized hole that I will have to weld up sometime in the near future.
Caliper and pads are now tomorrows job.
Hope swmbo doesnt mind too much as its her Birthday.
After that, need to pressure test the heater Matrix on the Boxster. Removed it last week and it look fine with no signs of leakage, despite having recently pressure tested the whole cooling system..
Bypassed it yesterday and drove the car to work tonight. No signs of the coolant smell, which is making me think matrix again.
Will remove it again and pressure test it, probably in a bucket of water and hopefully find a small leak.
After that its on to the Omega which has a coolant leak from the n/sf somewhere around the side of the radiator area, so need to pin down exactly where from and fix it.
If I can shift the Boxer soon I want to spend some time on the Omega bringing it back up to scratch as its ben pretty neglected recently, and they dont like that.
Raeturbo
Quote from: YZ250 on 30 May 2025, 20:07:23
Yes just arriving at the first stop 👍. Only just got phone coverage back.
YZ250
Quote from: Raeturbo on 01 June 2025, 05:23:51
That'll be Stavanger Norway then.  :y  We've done that cruise a couple of times, the scenery is lovely.  :y  You could get the ships internet package, or pay on just the days you want it but its bloody expensive.
Enjoy your time away.  :y
Quote from: YZ250 on 01 June 2025, 08:17:25
Don't tell him that!  It's been nice and peaceful in here.  ;D
Raeturbo
Now now QC, that's not nice😢   I've got the roaming for £15 that will do me for when we're at port👍
Rangie
That's on our list to do, after the Greek islands, enjoy your time away Britannia is a great ship 👍
Quote from: Migv6 le Frog Fan on 31 May 2025, 23:50:55
Be one of the thermoswitches ;)
Raeturbo
Quote from: Rangie on 01 June 2025, 16:04:22
GastronomicKleptomaniac
For.the umpteenth time I am very grateful to Addy of this parish. Repaired a buggered thread on the track Saxo* caliper so it's now a bit closer to completion.
*Traxo
*Thanks, Addy. Thaddy.
