countrywoman
Unless its an auto and they never get used and seize up come MOT time!!!
Quote from: countrywoman on 18 July 2025, 14:34:20
Precisely. The only parking brake I have ever had any issues with is the separate one on the Omega.
It's not just lack of use. I used my parking brake religiously. The friction surfaces never do any work so are never wiped clean of rust. They never get hot enough to drive moisture away and so on...
Quote from: Doctor Gollum on 18 July 2025, 09:20:26
Quote from: Andy B on 17 July 2025, 20:36:53
Quote from: YZ250 on 17 July 2025, 20:14:53
Next job is the rears.
Guessing it'll have a silly leccy hand/parking brake .... if so, is it easy to tell the car to wind the caliper off?
You can tell my ML via the dash cluster as well as via  diag box .... it told me just this week I need brake pads, which I assume are the rears cos I did the fronts last year.
The ML will have traditional handbrake shoes * so a rear pad change should be straightforward.
* Because, for all their faults, Mercedes engineers understand that where the parking and service brakes are separate, they are actually better.
Not so on many of the later ones, they switched when everyone else did.
The most recent car I have seen with drum in disc parking brakes was a 2021 Kia Sportage (which was quite a surprise!)
Quote from: Marks DTM Calib on 18 July 2025, 16:01:23
Perhaps, but thought Andy has a W164 ML which definitely has the drum handbrake set up....
Migv6 le Frog Fan
Yeah, but never mind that.
Whats the best course of action to fix my leaking thermo switch on the Rad ?
Replacement switch ?  (if still available)
Is there an O ring that could be changed ?
Gasket goo ?
countrywoman
Migv6 le Frog Fan
Might have one in the shed I can try that with.  :y
Quote from: Migv6 le Frog Fan on 18 July 2025, 20:52:09
Buy one of these, Albs, always handy
Arctic Hayes Plumbers Fibre and Rubber Washer Kit https://amzn.eu/d/bf4yaKN
Diesel till I die
The switches should be readily available, but it's possible that it's the plastic tank that has split. In which case a new radiator is in your future...
Unfortunately not. the R Class before it was ie top hat disc/drum set up as per an Omega & Senator, but this W166 ML uses a leccy parking brake on the disc. You tell it via the dash cluster similar to Alan's VAG above.
I've never needed to look, but wiill have to do sooner rather than later.
edit .... what Mark said  ;) ;)
Finally got around to adjusting the other side of the handbrake. It now holds most of the bulk stationary.
Also replaced the NSR abs sensor. Now have fully functional braking/stability/cruise again.
Quote from: Andy B on 18 July 2025, 22:40:07
Fair enough, didn't realise you went that new after the R Class. ;)
I wouldn't ''never'' but I rarely use it. Used when parking on a hill or when hitching up the wobbly box  ;)
Quote from: Doctor Gollum on 18 July 2025, 22:42:51....
A 14 plate is hardly 'new'  ;) though I've had it 6 years now
Quote from: Andy B on 18 July 2025, 22:44:05
Apparently the W166 started in 2012 :o
