MaxV6
fitted replacement NCDC2013 and display.....    (£110 delivered ,  all working,  with code,  satnav disk,  manual,  and mounting cage assembly just in case.... on the downside, it had a dire straits  cd still in it's cdc case....  offending item removed....  rapidly....  ....     )
anyone knowledgeable want to come round sometime and assist me in fitting parking sensors???    then there's  the crank sensor pissing out oil.....   and brake pads to do....
(got a dry (ish) garage,  with some lighting and heating of sorts....    ,  and big enough to get the Mv6 estate in to and close the door and still move around .....   )
biggriffin
Changed oil,fitted new front discs,
rubbed down some rust off both front chassis legs and repainted, refitted front splitter.
. Still got wishbones,droplinks and poly front bushes to do. :-X
Hoof'land storeman.
Buggered if I'm changing a stat in this weather.  -4 and foggy. bugger that, I'll use petrol instead. :(
Quote from: chrisgixer on 12 December 2012, 01:32:37
Farking freezing! So cold.. need to do the same job on mine as it sat at barely 80C for most of the journey to work..
Im hoping to put the alternator back aon the Cavalier again today.If it still leaks I will contact 2woody and see if his kind offer is still open.If I get the cav up and running,then I really need to change the dispack on the Omega,as the misfire is getting noticably worse.
After that,the stat on the Omega when I can find some time to do it.
Quote from: chrisgixer on 12 December 2012, 11:11:05
Stat party then. BRRRRRRRR ;D
Actually .. I'll be at home at a loose end on Saturday if you want to pop over and do it in the (slightly) warm(er) garage (that you can't shut the door on with an Omega in it .. but you can stand in front of the fan heater!) ;)
Need to do mine too :-X ::)
Nice big workshop up here :y (Although there's no heater at present so not exactly warm ::))
I must go and do an oil and filter change in the next couple of days :-[
Really, really need to do the oil & filter on mine, too.. Should have done it on Sunday but got too annoyed with the M3's brakes. I'm not even going to say how many miles it is since the last oil change  :-X
Quote from: aaronjb on 12 December 2012, 11:54:09
That makes me feel a little better ;D ;D
I'm overdue, but not too badly, and know I'm likely to do the best part of a change interval in the next month or so ::)
MaxV6
Quote from: aaronjb on 12 December 2012, 11:43:54
for some strange reason,  that makes me feel ever so slightly smug ;)
i wonder if its worth a chat to Guffer..?
Warmish garage available here if required. Only one Omega at a time, though, ;)
I say warmish. It was 0.6 degrees C this morning. :-\
MaxV6
5 degrees warmer than it was here !
(ambiently,    indoors and garage , MUCH warmer....   )
