Quote from: tunnie on 27 December 2012, 21:46:57
Quote from: TheBoy on 27 December 2012, 21:42:05
Keyswitches in 3 button fobs is relatively easy. Shop sells the switches ;)
Speaking of fobs, I need a new one for 2.2. Can you bring one tomorrow please?  :-*
Any why would I have one  ???
Quote from: TheBoy on 27 December 2012, 21:48:02
Thought you kept loads to code & sell?  :-\
That said, just found one, but its £12 and will need a new blade.
That going rate these days?
Buy from a dealer. About £27 plus VAT for the last I bought.
Quote from: tunnie on 27 December 2012, 22:04:29
Do not buy 2nd hand. For starters, how do you know its the right one ;)
Quote from: tunnie on 27 December 2012, 22:01:51
I'm finding a lot of blank fobs & buttons, but none that supply that board  :(
http://www.ebay.co.uk/itm/Vauxhall-Opel-Omega-Vectra-3-Button-Remote-Fob-Case-Blank-Flat-Blade-Key-/110951179755?pt=UK_Car_Accessories_Safety_Security&hash=item19d534a5eb
The ebay replacement cases are utter shite. I've been trying to find some to put together a kit for the shop, but they are all universally shite. Hence the recommendation to use dealer.
Quote from: TheBoy on 27 December 2012, 22:04:32
That cheap? Thought they were way more than that! Problem solved then.
That the whole key, or just fob bit?
Quote from: tunnie on 27 December 2012, 22:07:50
Just fob.
I may still have blades and transponders, as they are same across range (post 98)
So today oil and filter change + full throttle body and breather clean on 2.2. Also tracked down a pesky LPG leak, found to be on pipe of vaporiser.
New air fresher + new fob programmed. So quite successful on that car.
Not so successful, on little fattys rusty bullet's oil leak  ::)
Quite impressive lost b*stard bolt & 8mm socket somewhere in that engine bay!  ;D
And I've got a blister on my finger, helping to explain my butterfingers...
Quote from: TheBoy on 28 December 2012, 18:13:57
Next time I think take that PAS pump off earlier, before round 7  ;D
I suppose I ought to change the oil on Mrs VXL's estate...  :(
Quote from: VXL V6 on 29 December 2012, 10:21:34
The oil in the MV6 did 7.5k  :-[
Although, as its a constant loss system......    :-[
