Quote from: TheBoy on 12 December 2012, 18:48:49
Pick it up on your way home Fri morning :y
Cheers, might be more like early afternoon though  :)
Gaffers
Quote from: henryd on 12 December 2012, 22:46:14
Polished the Signum this evening,came up a treat too :y :y
Is that what you call yours?  Personally I get the missus to polish mine.  But, each to their own...... ;D
henryd
Quote from: Guffer on 13 December 2012, 13:44:58
;D ;D ;D
other rides
Got in it and tried to start it, it wouldn't go so I used the other one i've just changed the glow plugs on. I've now ordered a second set of glow plugs :-[
Keith ABS
I drove mine and filled up with diesel ready for the ABS Mimms meal tomorrow. cant wait for the drive. :y
keith B
Noted the petrol price had gone down , normally drop a tenner's worth in so treated the ole girl to £10.50  :-*
Run a bit of wiring ready for an up coming project :-X
Johnny English
#3877
Starter motor change is done !  :y I'm feeling proud as my abilities is absolutely not like a mechanic's...Many thx for the help I found on the forum !  :y
C20NE - X25XE
malcy_p
Cam cover gaskets - and new plug leads whilst I was in there!  ;)
If you're bored.... http://www.malcp.com/20121215OCG/index.html
/malc.
winter tyres and geometry for miggy + new custom hand made shocks for clit..
result : lighter wallet and frozen a*rs* ;D
Shackeng
Oil & filter change, and topped up the ATF, the hardest part of that is jacking up on stands and getting it level. :y
Washed three weeks of motorway grime off the DTi.
symes
done few bits on mate miggy basically sorting what a so called mechanic had done wrong like cam timing replacing broken electrical connector plugs etc which got it running again :y :y
Shackeng
I almost forgot, I also swapped my damaged :-[ front bumper for a good one i got from the Red Baron, looks nice too. :y
Murph
Dowty washers and hollow bolts changed.
No heat from the blowers now so looks like there's an air lock somewhere.
Fitted replacement wheel after a motorway blowout on way back from Alb's yesterday.
