Pages: 1 ... 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 ... 1939   Go Down
Author Topic: So what have you done to your car today?  (Read 7602219 times)
0 Members and 37 Guests are viewing this topic.
Omega_Dan
« Reply #480 on: 26 June 2011, 19:53:51 »
Did some underbody rust proofing and adjusted the bonnet cable so 'it works'  ;D
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #481 on: 26 June 2011, 20:01:52 »
Cleaned the gearbox electrical switch, fiddly job, but fortunately fixed the problem.
Then jacked up the Avenger and started on the brake upgrade; have one side ready to refit once I've had the (Capri vented) discs redrilled to fit the hubs.
Also noticed just how bad the 'MOT' repair on the O/S inner wing is; Tuesday I'll repair it properly.
bored bigyin54
  • south wales
    • black beast
« Reply #482 on: 26 June 2011, 20:34:41 »
pulling my hair out the last few weeks but all sorted now
« Reply #483 on: 26 June 2011, 22:23:06 »
Rotated the tyres front to back and noted the paper-thin brake pad friction material on the front. ::)
« Reply #484 on: 26 June 2011, 23:49:19 »
Rear bushes changed on Thursday as something at back has been clonking.
Typically, the clonking is intermittent and still there  >:(
Re organised all the crap in the cubby holes and wrapped the jack in a towel.
typically, the clonking.....
Fiddlesticks.
Friday night had to stop using the car as at no1 injector decided it would be better to fill the v with fuel rather than inject it in to the cylinder (what like it's supposed to) >:(  so...
Spent Saturday driving to Heathrow and back to collect a replacement inlet manifold/fuel rail.
Cheers Steve :y  Half hour later, all back together, fired up and all working with no leaks.
New inlet assembly still not solved other issue though. >:( Not sure if that is good or bad as it has ruled out the injectors and some of the loom. :-/
« Last Edit: 26 June 2011, 23:50:20 by 05omegav6 »
o-meg-a
  • south wales
  • avatar disabled meantime as its mahoosive!
« Reply #485 on: 27 June 2011, 00:46:54 »
Fiddlesticks.
clonking could be rear droplinks?
« Reply #486 on: 27 June 2011, 01:06:22 »
Fiddlesticks.
Be surprised. They are very different to the front. Big rubber washers that just push in. Rather than a ball joint.
Roll bar bushes
Subframe to chassis bushes behind the dif
Top/bottom shock mounts
Buggered exhaust or missing hangers
Loose spare
Incorrect shocks
Buggered control arms     ....?
« Reply #487 on: 27 June 2011, 06:55:49 »
1.Roll bar bushes
2.Subframe to chassis bushes behind the dif
3.Top/bottom shock mounts
4.Buggered exhaust or missing hangers
5.Loose spare
6.Incorrect shocks
7.Buggered control arms     ....?
Don't think it's 1,2,3 or 7 as its not every bump/pothole/catseye.
6 can be ruled out. Gen VX self levellers fitted new 18 months ago. s/l all working as it should. (thanks for the cheat in the subframe bush guide btw :y, alot easier that jacking the car up.)
5 well and truly screwed down and jack wrapped in a towel, though that did bang a bit.
leaves 4 and gearbox mount. :-/ there is enough play on the exhaust to bang it if you really try ::) will get back under it tomorrow...
Shimmy
  • St Albans
    • Omega 3.2 Elite
« Reply #488 on: 27 June 2011, 14:39:41 »
Bit of a frustrating day so far..
Made a thread about it.
Budget tyres, false economy.
« Reply #489 on: 27 June 2011, 14:49:51 »
Took the door handles off the breaker - cant be 4rsed removing doors and bonnet. Cleared the drive, ready for it to be collected by scrappy tomorrow. That was enough in this heat - seriously wilted in the heat after half an hour of exertion.
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
« Reply #490 on: 27 June 2011, 14:59:16 »
BTW Albs, I couldn't use the parking sensors off that so if you wanted to make a kit out of them and the ECU....
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
« Reply #491 on: 27 June 2011, 15:27:51 »
ECU etc. long gone Chris. Why couldnt you use the sensors ? :-/
Chris_H
  • E London/Essex UK
« Reply #492 on: 27 June 2011, 17:33:10 »
They're three pin and mine are 4 pin.  Diameter is smaller too, so I've opened out the holes in the bumper to take my existing ones and will have to source one new(?) one.
http://www.omegaowners.com/forum/YaBB.pl?num=1308645882
« Last Edit: 27 June 2011, 17:34:20 by ChrisH174 »
« Reply #493 on: 27 June 2011, 17:56:21 »
Are you going to replace the friction material with proper braking material, or stick you your favoured lumps of old oak :P
hotel21
  • The Kingdom of Fife
« Reply #494 on: 27 June 2011, 17:58:41 »
Took mine to work today for the first time in yonks.  Felt good to be getting quietly wafted along, rather than diesel rattled in the Landy!   ;D
Pages: 1 ... 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 ... 1939   Go Up
Page created in 0.021 seconds with 16 queries.
