Author Topic: So what have you done to your car today?  (Read 7880158 times)
0 Members and 64 Guests are viewing this topic.
« Reply #4860 on: 06 April 2013, 18:11:06 »
Yes, I did get off my arse and did the oil on TBE, need to double check the level though.
Changed its steering idler whilst there, though not convinced the Lemforder one has any less play than the 10yr old GM one. Suppose a drive will tell.
Got the Kwaka started, so to ensure all the condensation was blown out, and minimise all those nasty acids, I thought I'd take it for a trundle. Its actually colder out there than it looks ;D.  That said, within 6 or 7 miles of here, there are still 18" deep drifts at the side of the road...  ...and the melidioter crossing the road is enough to cause a minor butt clench.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #4861 on: 06 April 2013, 19:18:39 »
Swapped the AR25 in my TD for the AR35 that has been gazing at me accusingly from the corner of the garage for the last 3 years. Many thanks to JamesV6CDX for doing all the donkey work. It was a pleasure to pass spanners to you James. Fitting the V5 chip next :y :y :y
symes
  • oxford
    • R reg 940 volvo
« Reply #4862 on: 06 April 2013, 19:22:41 »
Finally fitted steering wheel in correct straight ahead position :y only been 3years in wrong position :D still at least it's done now :y
« Reply #4863 on: 06 April 2013, 19:24:28 »
On the Omega?
Tell me you didn't just take it off, and put it on straight :o
symes
  • oxford
    • R reg 940 volvo
« Reply #4864 on: 06 April 2013, 19:29:51 »
yes mate-no let me explain---3yrs ago I got nice condition steering wheel(buttons worked) and fitted it in bit of rush(as you do) went down road and it was not centered :-[  Well sorted it out--dont worry mate its not my tracking-honest :y
should have explained better -sorry :-[ :-[ :-[
« Reply #4865 on: 06 April 2013, 19:36:21 »
Phew :y
Worth double checking that the pitman arms are dead ahead when steering wheel is straight :)
symes
  • oxford
    • R reg 940 volvo
« Reply #4866 on: 06 April 2013, 19:49:15 »
Phew :y
Of course mate  :y :y :y followed your advice as you preach this-when on about steering problems :y :y :y :y :y
flexbuttcheck1
  • nottinghamshire
« Reply #4867 on: 06 April 2013, 19:51:06 »
rebushed the front suspension with polys and lemmforders  :)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #4868 on: 06 April 2013, 21:32:41 »
Fitted a new aerial base gasket to replace the ugly silicone mess that I used when a pressure washer destroyed the original.
I'm not allowed excitement.
« Reply #4869 on: 06 April 2013, 21:38:02 »
prepared the near final paint color today..  will see if minor corrections will be required.. this will be obvious after a few days of drying up under sun.. will have a final check on narrow angle colors..
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #4870 on: 06 April 2013, 22:43:08 »
She got another 12 months ticket with no advisories :y
Also noticed that they put the last 3 years mileage when mot'd on the certificate
« Reply #4871 on: 07 April 2013, 10:17:14 »
How much are valve stem seals  >:( >:( >:(
symes
  • oxford
    • R reg 940 volvo
« Reply #4872 on: 07 April 2013, 10:18:29 »
 good news mate :y
bad news :'(
symes
  • oxford
    • R reg 940 volvo
« Reply #4873 on: 07 April 2013, 10:20:00 »
for your pug??  :o cheaper than mig I bet ;)
« Reply #4874 on: 07 April 2013, 10:37:01 »
Not sure i want to get involved with so much technical work on it seeing as its destined for another owner , it smokes on start up from overnight but ok after that . Any additive that can be used  :-\
Page created in 0.026 seconds with 16 queries.
