Quote from: Kevin Wood on 24 February 2014, 10:58:25
Mmm. Plod electrics thinks I. Much frustration will it cause. Consume you, it will.
Consume the battery more like ;D About 120 amps fused on there :-X
The frustration probably won't start until I power it up... ::)
Both on the money though :y
Not quite today but Saturday I discovered the reason for the occasional misfire on cylinder 1..
At some point in the past the rubber boot on plug one had been trapped between plug top and coil pack spring contact - much arcing has ensued and the boot is now a crumbled mess.
Same story on cylinder 2, too..
Given the state of it I have no idea how it was running as well as it was!
Quote from: aaronjb on 24 February 2014, 12:06:21
Magic mostly, especially where electrickry is involved :-\
amba
Productive morning for a change,and also in the sun 8)
Traced the reason for the Headlight Field warning that has been plaguing me for weeks now.Damaged middle wire at the plug and also a split further up the loom almost into the wheel arch liner.All repaired and soldered so atleast that part of the fault is fixed,although now have fault message for brake pads yet again despite soldering in a new plug for that some months ago. >:(
It seems the wiring in that part of the wheel arch is very very fragile and the cores just perish by looking at them.Perhaps I have just disturbed something and it wil settle down after a few starts.
Cant be as bad as adjusting the handbrake system  ;D
cd 2.2
Had the exact same issue with mine late on last night (still got me home though). Tubes are all now super-glued where they were split and working well! think I need some new tubes though  ::) I'm told it's caused by sitting in oil when the top gasket fails
brian36
got my car back from marks dtm calib and went for mot which only needed light nearside adjusted otherwise all well and thanks again to mark :y
Quote from: brian36 on 24 February 2014, 16:15:10
He's a good egg really, despite whats written on the toilet walls
Gaffers
Quote from: TheBoy on 24 February 2014, 17:01:36
He's a good egg really, despite what I write about him on the toilet walls
fixed that for you :y
Quote from: Monsieur Guffer on 24 February 2014, 17:29:19
You promised that childish prank would be our little secret!
chrisgixer
Quote from: chrisgixer on 16 February 2014, 22:56:13
Topped up the screen wash. :)
Topped up the screen wash. :-\
...and the oil after the warning popped up on the cid. :-[
Stemo
Quote from: chrisgixer on 24 February 2014, 19:38:44
My cars never get low on anything. The nice boys at kwik fit look after that kind of thing for me. :y
Gaffers
Quote from: TheBoy on 24 February 2014, 17:51:31
Sorry, I forgot.
But I am stil wondering why you wrote your number on the wal though :-\
jonny2112
Quote from: Taxi Al on 24 February 2014, 10:53:51
Quote from: jonny2112 on 24 February 2014, 09:03:26
Quote from: Taxi Al on 24 February 2014, 06:39:16
Probably another 8 hours work left on it...
What are you up to Al? Or should I not ask   ::)
Patience young Jedi, much to learn you still have...
;D ;)
chrisgixer
Quote from: STEMO on 24 February 2014, 19:53:34
Your "Daewoo" must gets some stick sat is queue full of BMW and audi owners, and all the other eejits with more money than sense.
Stop messing about Esta, like their latest radio ad campaign, you need some "BMW economics" ;D
