Shackeng
Started rebuilding the interior following the wiring frenzy...
And broke a mates 1.4 Astra :-[
Managed to shear a throttle body bolt ::) fortunately it snapped about 4mm from the head, so should unwind easily enough with a pair of pliers :-\
Changed the cam cover gasket and cleaned the breathers whilst breaking servicing it. Main breather looked like it had been packed with copper slip :o
Ordered a new exhaust for the Silver Bullet, which had started to sound a bit loud ::).
So, just over 4 years from Eternal (replaced Dec 2009).
Lagondanet
Been to the tip to get rid of the stuff I cant get in my dustbin coz they wont give me a big one and to Waitrose to buy all things nice for Mumsy.
Thank god for a big bootie.
Lagondanet
Oh and ordered an Adam for SWMBO p/e for the Corsa.
Quote from: TheBoy on 29 March 2014, 18:07:05
Me too!
noticed one pipe to back box no longer attached,
and the other held on by about an inch of rust.
Does sound good though....if a little throaty, well beyond a blow...It has no back box in effect!
Finished it for now... Just needs a light bar and decorating...
DaveA
    Replaced both drop links, surprising the amount of noise they make, a slight knocking, which is at it's worst on smoothish roads, then a kind of background noise that you don't seem to notice until you change them, if that makes sense?   :)
Regards
    Dave
The Red Baron
My 3.0l mv6 has been off the road for a year.
full brake strip & clean.
new tre`s on both sides, in for the mot end of this week & it (should) be back on the road.
cant wait  :D
cd 2.2
Started major job late this afternoon (well not that major to be fair)!
Replacement "Moog" wishbones, Apec front discs and matching pads, some brake fluid, New camshaft sensor and a catalytic convertor and gasket for the cat to down pipe joint for !£349 inc VAT! Added bonus of a £12 refund when I take the knackered catalytic convertor back for exchange  :y
I hope its not a pattern cat, not seen a good one yet  :'(
biggriffin
 filled it with tesco 99. :-X might go and see the angry albainians later to get it washed :y
Hoof'land storeman.
Fitted the repaired CDL motor that I did before I went on hols to the MV6. The duff one that's come out I'll refurb tomorrow, and slap that in the passenger side, as that's also failed ;D
Taxi_Driver
Quote from: biggriffin on 30 March 2014, 12:26:08
I did that today.....tho' they might be cosovans or whatever....£10 inside and out plus a nice dangly rear view mirror air freshener  :y ;D
Quote from: Taxi Driver on 30 March 2014, 19:54:37
Went round to see my best mate to borrow his hose and pressure washer, as I worked out the Kosos were going to want about £35 to clean my 3, all of which are minging. So due to my moment of tightness, guess what my plans are for tomorrow ;D
