That will be fine :y have one myself, though I paid about a third of that from Homebase
Good for incinerating bushes/plumbing jobs and general pyromanic behavior too ;D
Quote from: aaronjb on 01 April 2014, 13:55:16
This is what I have, along with a can of MAPP gas: http://www.ebay.co.uk/itm/Rothenberger-Superfire-2-Gas-Soldering-Brazing-Blow-Torch-Mapp-or-Propane-/291112233086
Gets things nice and toasty and is about as good as you can get without getting an acetylene torch in (which isn't really practical in a home setting!)
Snap, as used a few times at Newent for lighting the gas cooker with.  :y
Quote from: Marks DTM Calib on 01 April 2014, 15:22:12
Pretty sure it was on your recommendation (perhaps not directly :)) that I bought it - and very pleased with it I've been, too :y
Great for helping a friend burn himself on his RX8 exhaust... ;D
Quick question then ... having never played with the rear tie-rods ... I assume (dangerous I know) that the two big "nuts" are lock nuts that need loosening before the centre bar can be turned ... so .. which one is the "wrong handed" one .. inner or outer ??? As it might make life a tad easier knowing which way to try and turn them once hot !! As they stand at the moment, soaked in plusgas, they have as much chance of moving as mount everest does !!
Quote from: Entwood on 01 April 2014, 16:41:19
Sadly I dont remember but it matters not really as they can turn in any direction as long as they come free.
Pay close attention to the threads...free the lock nuts first then unscrew the centre rod :y Off memory I don't think that they are sided, so what works on one side will be mirrored on tother :y
Washed it... apparently it's white rather than the dusty matt grey it had become :-[
Still scrubs up nice though 8)
That is if you ignore the stone chips and rusty bits :-X
Stemo
Quote from: Taxi Al on 01 April 2014, 17:40:38
That would make an excellent eBay advert.  ;D
Cleaned up front brakes to sort awful brake squeal....
pscocoa
done nothing to car again and not touched it for 12 months apart to put petrol in and occasionally check oil (it never uses any) . Stop messing with these bloody cars and get some value from them as tools to serve you.  >:(
Shackeng
Quote from: Entwood on 31 March 2014, 20:15:29
Swore lots ....
Changed both wishbones ... both ball joints would not come out of the pinch bolt holes with any ease at all ... despite the pinch bolt being completely removed and a cold chisel well buried in the "split" ... managed it eventually with a lump hammer and a drift on the boltheads of the ball joints .. I didn't want to muller the old ones as Joff  wishes to refurb them.. hopefully the damage is within allowable limits ..... :(
Swore lots .....
Offside new one in position, holes line up first time ... so I manage to drop the bolt into the chassis void ... :( .. drive to swidnod .. luckily Skurrays had bolts in stock .... bit of string around the bolt for safety, went in first go ......offside TRE adjusters checked, nice and free ...
Swore lots ....
Nearside new one would not line up, simply could not get the vertical bolt in even after an hour. Took it all apart again, went for coffee, back out .. lined up first time ..... but then the ball joint would not go in ... took over an hour before that suddenly just decided to go.....  nearside TRE adjusters "solid as a rock" .. now soaked in plusgas ...
Swore lots ....
Both rear TRE adjusters also seized solid .. more plusgas
So tomorrow its more plusgas and possibly the weedburner to heat them up, if that fails its take the whole things off and use the kitchen stove .... as, according to Mark DTM .... heat always wins ....
wondering how much the bolt in the chassis rail will rattle
... might have to squirt some waxoil down it if its too noisey ...
I have a magnet on a flexi shaft that I got mine out with Nige. Feel free to borrow. :y :y :y
Shackeng
I took mine off and did it in the vice. Much easier! :y
Quote from: Shackeng on 01 April 2014, 18:33:12
I tried a magnet on a stick .. failed spectacularly... magnet kept sticking to the chassis rail .... and then started to bend excessively .. so I gave up !!
Checked the intercooler on the bus. Earlier today I ragged the nads off it, trying to redline in every gear, partly out of hatred for it and partly to see in an Italian tuneup would help.
